USB issues X32
Discussion in 'CNC Mills/Routers' started by Alexander Idfalk, May 16, 2025 at 9:24 AM.
  1. Alexander Idfalk
    Howdy,
    Akll of a sudden, I cannot connect to my Ratrig Stronghold through the blackbox x32 via USB and My Macbook. This has never happened before and before posting this I have tried to follow the instructions recommended on some different but similar threads. I have tried different USB-cables and also disconnecting everything except power and USB. Also, MacOS seems to recognize that there is something connected via USB but nothing can be connected in OB Control.
    Please help, this is so frustrating.
    /Alex
  3. Alexander Idfalk
    Hi and thank you. Yes, i have read the documentation you refer to, which led me to test without anything connected. (I assume I still have to have the power supply connected though). So, since the problem remains - next step is to test with a different computer or assume the controller has been damaged and need to be exchanged?
    Thanks again.
    Correct, if its been damaged a) find what damaged or plugging in a new one will just damage it again right away, then b) order a new controller and install it
    Hopefully its a computer problem, easiest test is indeed to try a different computer
