Using pause job in control software
Discussion in 'General Talk' started by FrankM2020, Feb 12, 2021.
  1. FrankM2020
    Hi. I'm trying to figure out if pausing job via" pause job" should retract bit from material and turn off spindle and reverse this when "resume job" is clicked. as of now pushing pause just stops the file. spindle just keeps spinning in material until I hit resume. have searched this topic and not found the info I need.
    Any help greatly appreciated
    Pause = feedhold. It is a pause only. Nothing else happens (nor is it supposed to)
  3. FrankM2020
    Well thanks for confirming. Is this something that could be added in a future update?
    Nope, Its how grbl works internally. See gnea/grbl scroll down to "! Feedhold"
    The action you refers to is not part of "pause" (never will be) but is part of the Door interlock switch - its called Parking. See gnea/grbl so consider adding an Enclosures - OpenBuilds Part Store around the machine and then wiring a docs:blackbox:connect-door-sensor [OpenBuilds Documentation]
    #4 Peter Van Der Walt, Feb 12, 2021
