Using two gantries.
Discussion in 'CNC Mills/Routers' started by Joseph Casalino, Apr 19, 2022.
  1. Joseph Casalino
    Hi,
    Because the part I want to mount on the gantry is so long, I was wondering if I can use two gantries on the same rail? They would be a few inches apart, both attached to the lead screw. The part and its positioning fixture, weigh about 10 Lbs. Will the normal motor work on such a load?
    Thanks,
    Joe Casalino
