Vcarve Toolpath Issues
Discussion in 'CNC Mills/Routers' started by rbrown55, Oct 28, 2024.
  1. rbrown55
    rbrown55 New
    Hello all
    I am trying to run a vcarve toolpath on plywood and it is coming out very rough. I have it set to a flat bottom depth of .04 and have tried just a 60 degree vbit as well as using the clerance tool option, Vcarve Pro Software, but had to use a 1/16 bit as the text was pretty small. Even with that it didn't come out very clean.
    The router/bit is set to run at 18k rpm and 100 in/min feed
    Any thoughts on what could be happening?
    I ran it on mdf and it looked great
  2. Giarc
    What kind of plywood? Some just do not cut well. A down cut endmill will help to keep it from chipping out.
  3. rbrown55
    rbrown55 New
    Birch plywood
    trying to use the v bit because the letters are too small for an end mill.
  4. Christian James
    Christian James Journeyman
    Have you tried using the V-bit without having "Flat depth" selected?
    Also, possible moisture in ply?
  5. rbrown55
    rbrown55 New
    No because I want the flat depth look for this particular project.
  6. rbrown55
    rbrown55 New
    If it were moisture would I see the same result using an end mill?
  7. Christian James
    I would think it would be bad with any bit.
