Vectric Design & Make
Discussion in 'Other Software' started by Randy, Aug 26, 2020.
  1. Randy
    Randy Journeyman
    Can I use this software Design & Make Machinest for 3D machining?
    If so could you tell me what post processor to use please as it does not specify openbuilds machines.
    There are a few generic processes but again I am not sure which one to use.
    Thanks,
    Randy
      File size:
      63.8 KB
      42
    Is there a Grbl post?
  3. Randy
    Randy Journeyman
    yes there are several but I am not sure which one to use? let me create the file again and I will post a pic of the options. That might be easier.
  4. Randy
    Randy Journeyman
    Ok here is what is offered.
    Installed it to help you look:
    I only see two Grbl posts (0.8c is very old though, 2013ish) so might need some editing
  6. Randy
    Randy Journeyman
    ok well perhaps I will try it in aspire then. It looked like a pretty quick and easy program to use but if I have to start fiddling with code and such....Well you know how that is going to go.
    Thank you Sir
    With Vectric the learning curve isn't too bad because there are tonnes of youtube tutorials - bigger user base means more sample projects, tutorials and advice :)
    Though you'll hear less from me on questions about it, theres guys on here that know Vectric a lot better than I do
