anyone hooked up a Vevor spindle? I'm rather confused at wiring and setup of all the functions. ultimately want it controlled by the blackbox/interface. the manual is FULL of technical information, but rather lacking in the most basic stuff. like which wires from the VFD go to which pins on the motor. .. I want to have a decent understanding what goes where and how I'm doing it before I actually start. thanks
It should be no different from the HY VFDs. They are all just copies of each other. DCM, ACM, VI, and FOR are your connections. VFD Spindle Control via OpenBuilds BlackBox Controller and Software Double check your parameters match the spindle as well.
