VFD and Laser connection
Discussion in 'General Talk' started by Romain Wood, Dec 29, 2021.
  1. Romain Wood
    hello I currently have a vfd spindle and want to wire an OpenBuilds WorkBee CNC Eco Saver Laser Upgrade with PLH3D-6W-XF + laser as well.
    I would like to have a fixed wiring for the two tools and switch with a switch between the two in focus of either machining or laser.
    is it possible?
    I have watched the videos below
    My laser
    Engraving Laser Head - High Power CNC Laser | Opt Lasers
    documentation for lead and workbee laser
    OpenBuilds LEAD/WorkBee CNC Laser Upgrade Setup Guide
    My spindle
    Broche refroidi à l'eau 1.5 KW + inverseur VFD 220 V
    and for cablage
    21 octobre 2020 – Blog PC-CNC
    So in the idea there would be that the son which is connected to the blackbox to the GND port which is connected to the switch with the choice of either the pin or the laser?
    Thank you for your help and advice
    You can wire switches yes, unlike docs:blackbox:iot-and-laser [OpenBuilds Documentation] though, which both uses the PWM signal, you have two signals (PWM and 0-10v)
    You will need a DOUBLE POLE DOUBLE THROW switch
    Use one half as the PWM side, the other as the 0-10v (do not cross these signals, it will damage the BlackBox) wired such that throwing switch left connects VFD to the 0-10v, and throwing it right disconnects the VFD from the 0-10v, and connects the PWM to the Laser. Or you can wire two seperate switches
  3. Romain Wood
    That switch is perfect, but the wiring is incorrect, that will direct the BlackBox PWM wiring between the VFD and Laser, of course the VFD wants 0-10v, not PWM - thus it won't work
    You should use both halves of the switch to keep the seperate signal voltages, seperated.
  5. Romain Wood
    thank you for your answer, I have a doubt about your diagram because the ACM goes on the GND of the black box and on your diagram they are on the same side of the switch
    I got it from your diagram. If ACM = GND it doesnt belong on the switch at all!
    Should be whatever the VFD terminal is that the 0-10v goes into, that one...
  7. Romain Wood
    this is how my pin is wired
    Connection of the "VI" connector on VFD to BLACKBOX "0-10V".
    Connection of the "ACM" connector on the VFD to BLACKBOX "GND".
    I'm sorry but I'm very bad at electronics so my questions and questions may be absurd but I don't want to damage my VFD or my black box.
    thank you for your patience
    Ok, so VI then where I wrote ACM
    VFD namings are confusing
  9. Romain Wood
    thank you for the answer so I have corrected the wiring on the photo
  10. Romain Wood
    so here is the wiring to connect the laser and the spindle
    is it correct?
  11. Peter Van Der Walt
    Looks good! Perfect
  12. Romain Wood
    perfect
    thank you very much for your help and for your patience
