felt confident that I had read enough documentation to start wiring the vfd without running into problems. But I popped open the front cover on the YL620-A and noticed that my vfd looked slightly different than most of the reference material I had researched. So can someone verify my mock up picture/drawing? Jump FWD and XGND and 10V and GND to “toolhead” plug on BB. *Also noticed I drew the colors backwards on the 10V and GND wires* If it’s good I’ll wire it up and move one. Super close to test cuts
Officially (because we don't sell VFDs, and they differ so much from different sources sometimes) that we only provide: OpenBuilds BlackBox 4X Documentation Reading your VFDs manual should help you on how to connect an external 0-10v input Unofficially, there are a couple awesome forum members working on a writeup here: see Blackbox VFD question ***Solved: Added howto guide*** and more detail in XPro v4 won't control VFD & Spindle and BlackBox
Not that long ago, I was looking at purchasing that one over the HY version due to it being cheaper and i did not need tall the features the HY has. I did a Google search on it and found various threads and videos on hooking it up. Also, Amazon sells the kit and several reviewers describe exactly how they solved the hookup. Amazon customer reviews are a great source of technical knowledge sometimes. I will often read a bunch even if I purchase elsewhere. However, this is for the 110 v version which is what I want. The hookups should be similar. https://www.amazon.com/MYSWEETY-Coo...110+volt+1.5+kw+spindle&qid=1570464139&sr=8-2
Did that set up work for you with your spindle? I have the same vfd and trying to make sure I wire it correctly. Thanks in advance
Awesome thanks for the reply I’ll try it out next weekend I’m waiting for the shielded cable should be here on Monday.
Do you have your black box jumper on the m8/m9 jumper. You only had to put the red and black wires into those ports you didn’t have to do the fwd/com
Jump XGBD and FWD then on “toolhead” plug on BB pin 1 gnd to gnd on vfd and pin 4 0-10v to VI1 on vfd and it’s M3/M5 in the BB
Making You wouldn't happen to have a summary of the VFD setting to make that work (with just the 0-10v signal, no need to relay FWD) We have a proven setup for Hunyuang VFDs here: VFD Spindle Control via OpenBuilds BlackBox Controller and Software So if you have a moment to do a similar writeup for the YL620-A I'd happily link it in the docs too: OpenBuilds BlackBox 4X Documentation
