Vibrating machine
Discussion in 'CNC Mills/Routers' started by Dennis Roberts, Apr 23, 2021.
  1. Dennis Roberts
    Hi everyone
    I am having a little trouble with my workbee 1010. I have been engraving and cutting Charcuterie boards out of 1 inch Walnut. Everything was going fine cut out 22 boards and my machine started to vibrate real bad ripping the board of f the spoiler board. I had no problem with any of the other boards so thought I would change bits maybe the bit was dull but did it again with a new bit. First bit for the 22 boards I was using a 1/4 inch downcut and then switched to 1/4 upcut same issue but was able to stop before it went wild again.
    Board cut out.JPG Any thoughts?
  2. sharmstr
  3. Dennis Roberts
    Hi Shaw yes seems like its when the cutter goes around curves is when its realy bad
