What do you all think about this ATC?
Discussion in 'CNC Mills/Routers' started by 22878, Jan 16, 2021.
  1. 22878
    22878 New
    I was thinking about adding a ATC to the 1515 that I'm building. This actually seems relatively simple and straightforward. What do you all think? Is this something a beginner like myself could set up? I mean, I know I would need to get someone to help me with the tool change coding (the coding in the video is available on Github), but otherwise, is it doable?
    #1 22878, Jan 16, 2021
  2. Rob Taylor
    The Kress ATC is already pretty well known and documented. For a 1515 1000W probably makes sense due to the low rigidity of the extrusion, but at around $1500 all-in, I think a higher-power water-cooled ATC spindle for about $2k makes more sense- and will likely be what I end up putting on M4, once it's working enough to justify itself. Especially at these high spindle speeds where torque is at a premium, every watt of power matters.
    But if it was a MM-1000DI vs like, a DeWalt or Makita, the Kress wins all day, it's not even close (though the price difference makes that clear). Then the upgrade later at ~$1000 is less of a burden. I don't know that I'd use an ATC with straight grbl though, even with bCNC as a sender. I think I'd move up to either grblHAL or LinuxCNC.
