What is the Maximum Feed Rate ...
Discussion in 'CNC Mills/Routers' started by Scott Thompson, Jun 9, 2021.
  1. Scott Thompson
    for a LEAD CNC router design?
    If you spend a little time tweaking gnea/grbl and gnea/grbl you should be able to get to above 4000mm/min - depending on the exact machine setup. Our default, conservative, machine profile sets it to
    Our LEAD1010 Laser profile runs 4000mm/min: See OpenBuilds/OpenBuilds-CONTROL (Laser lighter than a router)
