What kind of lubrication for ball screw?
Discussion in 'CNC Mills/Routers' started by Srđan Marković, Aug 10, 2020.
  1. Srđan Marković
    What kind of lubrication can I use for 20mm ball screw? Is Motip-PTFE-OILl-500ml.jpg this spray good enough? Thank you
    Does your Ballnuts have a Grease Nipple? Most do, and require packing with Grease (using a grease gun)
  3. Srđan Marković
    Yes it does. What kind of grease silicon, graphite? I thought to use ptfe spray, is it good?
    Usually a light lithium grease, but check the data sheets of your specific leadnuts just in case
