What setting in grblhal do I set for the IOT to turn on my spindle?
Discussion in 'CNC Mills/Routers' started by Xafod, Aug 7, 2023.
  1. Xafod
    Xafod New
    I have the Blackbox X32 and got my IOT in today. Two wires connected to the Tool connector polarity connected right but I have no idea what settings I need to change in grblhal so it’s enabled
    Nothing - should already work. Use the Tool on/Off menus in CONTROL to test
  3. Xafod
    Xafod New
    I have the router plugged into the NC and the control wires plugged into the Tool sensor but if I enable the Spindel it doesn’t turn on. I will check for voltage on the control wires when I get home
  5. Xafod
    Xafod New
    I got it working... one of the control wires was not in the connector so it wasnt making contact.
    Thank you for your help!!!!!!
