What should be added to an order for a LEAD 1010 so it could be built as 1000mm x 500mm?
Discussion in 'CNC Mills/Routers' started by Fred Walter, Dec 23, 2019.
  1. Fred Walter
    What should be added to an order for a LEAD 1010 so it could be built as 1000mm x 500mm? The idea is to be able to rebuild the machine as 1000mm x 1000mm using the original parts, when there is space for the larger machine.
    If I'm correct, I would need to add the following:
    - (3) of "V-Slot 20x40 Linear Rail" (500mm length) <V-SlotĀ® 20x40 Linear Rail>
    - (2) of "C-Beam Linear Rail" (500mm length) <C-BeamĀ® Linear Rail>
    - (2) of "8mm Metric Acme Lead Screw" (540mm length) <8mm Metric Acme Lead Screw>
