Where can i get a drilling jig?
Discussion in 'General Talk' started by DVO, Jan 11, 2022.
  1. DVO
    DVO New
    Hi. Does anyone know where i can get a drilling jig for v-slot? I'm based in the UK BTW.
    I saw this jig that someone made...
    V Slot Drilling and Taping Jigs by FunKing3d
    It looks good but I don't have access to a 3D printer and the bushings weren't available on Amazon.
    I also found a company selling a jig but it was around £282, which is way too expensive.
    Drilling Jig 5 - MBS Item
    They’re really not that hard to make yourself. What are you wanting to do with it, end drilling?
  3. DVO
    DVO New
    I want to use holes instead of brackets to connect the profiles. Ideally, I want a jig to drill 3 x holes in 20x60 v-slot extrusion.
  4. Rick 2.0
    If you’re talking 5mm holes it’s fairly easy to knock out a jig from a 1” scrap of 20x60 and a small block of wood. At work right now but when I get home I’ll make a quick sketch of what I’m referring.
  5. DVO
    DVO New
    OK thanks. I should note that i don't really have any tools to make anything, hence why i wanted to buy something. However, if it's easy to do then i'll look into it ;)
  6. that-jim
    that-jim Journeyman
    I have used short off-cuts of extrusion as a drilling jig. kinda like this...
    Rick 2.0 likes this.
  7. DVO
    DVO New
    Ah right. And it works ok? Something like this crossed my mind but i was concerned that the holes would be too small. I'd like to reuse it often, and so i assumed i would need to put some bushings in the holes otherwise it would damage the aluminium when i drill. P.S. I don't have a drill press.
  8. Rick 2.0
    Yes basically what @that-jim said. And you really don’t need a drill press. You’ll find as you drill out the lengthwise holes in the 20x60 the bit is somewhat self centering as it follows the path of least resistance down the center of the hole.
    DVO likes this.
  9. Peter Van Der Walt
    With the lack of tools I'd highly recommend brackets instead. The through bolt method also requires you to perfectly square the ends. Brackets are easy, much stronger, and easier to square up properly
  10. DVO
    DVO New
    Ok that's good to know. I'll look into this option. Thanks :)
  11. that-jim
    that-jim Journeyman
    I drilled with a smaller 'pilot' drill then came back and enlarged the holes freehand. This will last for a while but if you have a lot to do you might want some thing with bushings. You could even use the extrusion to establish the spacing for a more permanent jig.
    Rick 2.0 and DVO like this.
