Which spindle?
Discussion in 'CNC Mills/Routers' started by lkvapil, Mar 22, 2020.
Tags:
  1. lkvapil
    lkvapil New
    Hi,
    I would like to ask for help. I'm looking for spindle for my upcoming CNC router.
    I would like to cut aluminium and try steel.
    My budget for VFD + spindle is max. 250USD
    My two options are :
    Spindle Motor Air Cooled 220V 1.5KW 24000RPM 400Hz ER11 Collet Wood Engraving Milling Machine STEPPERONLINE CNC VFD Motor 220V AC Spindle 4 Bearings
    + stepperonline VFD
    or
    US $215.0 30% OFF|New CNC 1.5kw 220v/110v Square Air Cooling Spindle ER11 1500W Air cooled Milling Spindle + 1.5KW VFD Inverter + 13pcs/set ER11|spindle fiber|machine folders|machine counter - AliExpress
    Thank's for any suggestion
  2. Kevon Ritter
    Kevon Ritter Veteran
    More info is needed, but I'll tell you right now that you aren't going to be cutting steel. What machine did you go with? Are you running 220V/240V?
    Something to consider is that both of those options are air cooled and only have ER11 collets.
  3. lkvapil
    lkvapil New
