will the black box run external stepper drivers?
Discussion in 'CNC Mills/Routers' started by J.Losoya, Jun 2, 2021.
  1. J.Losoya
    J.Losoya New
    Joe here, I'm trying to build a small CNC mill. I would like to know if a black box would run two nema 23 and a larger nema 34. or would it be better to use a Smoothe Board.
    Depends on the actual specs. NEMA is but a mounting pattern, describing the bolt hole pattern and face dimensions. It says nothing of its electrical specs. :)
    You need the coil voltage, inductance, resistance and amperage ratings.
  3. J.Losoya
    J.Losoya New
    Oh ok, yeah I have that, I will post that in a bit. Thanks Peter
  4. J.Losoya
    J.Losoya New
    here's what i have for the smaller stepper motors.
    here's what I have for the larger stepper motor
    It will have no issues with the NEMA23s (those are our motors yay)
    The NEMA34 will run, although underpowered by about 50%. You might be better off with a NEMA 23 Stepper Motor - High Torque Series instead - as the BlackBox can drive it more efficiently.
  6. J.Losoya
    J.Losoya New
    The mill I’m using it a grizzly G0463, and has a rather heavy spindle assembly, not sure if high Torque Series would work.
