WIN a Free Smoothieboard! [CLOSED]
Discussion in '* CONTESTS * Win Cool Stuff!' started by MaryD, Mar 21, 2017.
Thread Status:
Not open for further replies.
  1. wiremonkey
    I'm super excited to build the larger C-Beam!!!
  2. wiremonkey
    I'm going to build my first CNC machine, the larger c-beam. I'll probably lift the Z-axis for more clearance. I'd love to use this smoothieboard for that build.
  3. Mechtek
    Mechtek New
    I would use it for my very first cnc build being the ox-metal build.
  4. Aeroengineer1
    I am looking at doing a 4 axis laser engraver with this. Let's see what comes.
  5. Michael Morgan
    I'm currently using an Arduino based board in an external box. This controller runs both a 500x880mm OpenBuild CNC and a 60watt Laser. I would like to swap out the Arduino for a Smoothieboard making this controller compatible with LaserWeb/CNCWeb.
      File size:
      142 KB
      116
  6. CTW
    CTW New
    I would use it for for second year level three engineering course project for a cnc router/laser cutter with quick switch between the two.
  7. Tallaustin
    I would use a smoothieboard to control a desktop cnc mill. I use one currently on my homemade delta printer and it works very well!
  8. André du Plessis
    I will use the Smoothieboard to control my (currently in design) CoreXY.
  9. Jim S
    Jim S Well-Known
    I'm working on an idea for a multi-filament extruder that would be perfect for a board like this. Additional steppers and temp circuits would be very nice to have.
  10. ComicBit
    ComicBit New
    Tevo Tarantula, i have used it because the integrated MKS Board is terrible
  11. myoung
    myoung New
    I'd use a Smoothieboard for better control of my in-progress delta bot. It has 0.9deg steppers and needs 32-bit.
  12. mlopezaz
    mlopezaz New
    This would be a perfect piece of gear for my 3D printer build.
  13. Craig Thayer
    My first 3d printer build likely a prusa I3.
  14. Eric Kiser
    I would upgrade my original delta (Delta Force) from BBB/Cramps to Smoothieboard. I just started the upgrade ball rolling after calibrating and proving out the DReD-Bot (D-bot Build). The delta is in for an all-over upgrade - linear rails/bearing, new stronger carriage design, titan aero, ir bed leveling, small touch screen control, maybe some 0.9 deg steppers, and a total re-wire job (swapping controls to bottom from top.
  15. WhiteRenard
    I'm planning on building a delta (it'd be my first delta) and a 32bit board would be awesome! :p
    It'll be my 3rd printer... Do I have a problem? haha
  16. nsb807
    nsb807 New
    I would use it to build my HIGHLY customized C-Beam Machine. I have one in the works right now and this board would allow me to take it to a whole new level, maybe even a hybrid mill/3D printer.
  17. Miguel0706
    For sure i will use it in the Dbot i am getting the parts for. It will save me to be worry about the control board.
  18. just3D
    just3D New
    Been wanting to build a CNC router and the smoothie would be a good start
  19. Ulisses Lopes
    I'd replace the controler board of the Cobblebot 3d printer that I'm trying to build.
  20. Airplane1
    Airplane1 New
    A new CNC Router
  21. RenegadeSix
    The Delta printer I'm in the process of building! The brains is the last part im up in the air about! Cant decide between a smoothie board and a Duet. This would certainly make up my mind pretty quickly haha
  22. mwwood77
    mwwood77 New
    As an engineer with lot of mechanical design and ideas I would love to build my first cnc gantry router. This would be a solid start to be able to make more machines and prototypes.
  23. funjon
    funjon New
    I've been thinking about building either a D-Bot, or maybe a larger aluminum framed cartesian. Just gotta find room to build it in the house!
  24. Luke Ingerman
    I would use this on either my current D-Bot CoreXY build or a future Delta build.
  25. alanfj
    alanfj New
    For my first build; a C-Beam-GTC variant similar to GinoTheCop .
  26. a vila
    a vila New
    I would use it to upgrade my Folgertech f5 3d printer MKS Gen V1.4 Controller Board
  27. tangent82
    tangent82 New
    Doing my first real build (previously made a tiny 3d printer from cd drives from an instructable and my prusa i3 clone from a kit). Trying to make a large enclosed delta printer with auto-leveling and a 3 into 1 mixing extruder for color 3D printing, and ultimately I'd like to hack together a 5-into-1 mixing extruder to get full color with black and white. Already have the components for it, and the skeleton of the frame is assembled - basically a 2020 Kossel at this point, but the electronics bay, bed holder, and power supply will be made from up-cycled e-waste. The smoothieboard would be much better for this than the cheap MKS GEN clone I can afford on my grad student salary.
  28. Bill Meade
    I would use it on my new custom laser I am currently building with Open Build parts.
  29. nathaniel petre
    Building a large format printer, 2500mm x 800mm x 800mm for printing surfboards.
    Smoothieboard would be ideal
  30. Bryan Dix
    Bryan Dix New
    I would incorporate the smoothie into a multi purpose controller box that can be moved between projects
Thread Status:
