Workbee 1510 - crazy sounds, vibration
Discussion in 'CNC Mills/Routers' started by dsevencz, Mar 14, 2021.
  1. dsevencz
    dsevencz New
    Hello, i little speak english, but I try to start workbee it and all the axis vibrate madly and creak (video with sound in attachment). It doesn't matter what speed. I don't have the electronics fixed yet in drag chain, but that shouldn't matter.
    I have tried to disassemble it all several times, I have also tried the wheels to see if they are driving correctly. The screw connected to the motors is easy (with wheels), no snags, just a clean feed. He completes the task correctly, the dimensions fit, but at the same time he roars madly. I tightened all the screws, etc.
    Don't have a tip? Thanks in advance. Thank you...
  2. sharmstr
  3. dsevencz
    dsevencz New
    Hello, thank you, but it wasn't that. I had to calculate the steps correctly with velocity and acceleration, because the vendor wrote different settings than the diagnostics in the mach3 software calculated. Then the vibrations stopped.
