Workbee Rapids?? Black box
Discussion in 'CNC Mills/Routers' started by Dave Dreher, Mar 6, 2020.
  1. Dave Dreher
    Hello
    I’ll start by saying this is user error or inexperience
    let’s say I cut at 70ipm. My machine will move at 70 the entire time. So even when moving to next cut position
    how can I get faster movements when not cutting. Black Box and workbee
    thanks
  2. Rob Taylor
    Look at the explanations of grbl's settings on this page: gnea/grbl
    $110, $111, $112 control your maximum rates by axis. If left at defaults, rapids and jogs will be very slow, and cutting feeds will be limited.
    $120, $121, $122 control your maximum accelerations by axis. If left at defaults, you don't have enough physical room in the machine to get up to full speed.
    X,Y speeds on belt-driven extrusion machines should comfortably be able to be 5000-10,000mm/min. I think acceleration can easily be 2000-3000mm/s/s, but I forget exactly what it is on mine now. Just keep increasing it until your motor stalls out right at the beginning of a G0 move, then back it off about 10% or so.
    Z numbers will be slower, of course, with gravity and the screw.
