Workbee with Black box
Discussion in 'CNC Mills/Routers' started by eddie1681, Apr 8, 2020.
  1. eddie1681
    eddie1681 New
    Hi
    I am in the market for a workbee, My friend have a workbee that he wants to sell its brand new. The kit only comes with the frame and 2.2KW spindle kits. I don't see any hardware like stepper motors or any electronics
    I can buy it for a good price, can I complete this with the Openbuilds black box?
    What is the list of parts do I need?
    Can someone help point me to the right direction please
    I am very new to all this, I have a 3D printer but nothing like this. Please bear with me if I have too much questions
    TIA
  3. eddie1681
    eddie1681 New
    Thank you so much for the reply, is the DWP611s good for aluminum cutting? I plan to get all the items you listed and the high torque stepper motors. hope it will be easy to install everything. Is ther manuals or Tutorial on a build for beginners?
    TIA
    Plenty good enough when paired with CNC Router Bits - OpenBuilds Part Store - flex in the frame is the more limiting factor than the spindle; a Minimill is a lot more rigid than a large router for example, more a matter of picking the right machine for the task at hand (but with the right cutting recipe the Workbee can do Aluminum too)
    YouTube
    Just check with him where he got it - it may be a fake if the price is too good and maybe the reason he gave up on it? (;
  6. eddie1681
    eddie1681 New
    I need to find out, it could be from China. I am not sure. IF it is would all the parts you mentioned still work for it?
    whats the difference from Openbuilds and say like SPAM 3d. they just copied it?
  7. Giarc
    Quality assurance and customer support is the main difference. You will get help when needed from OpenBuilds. Also, the parts are not sourced from the same supplier. The Chinese V wheels are crap. They will crack. They do not use a precision shim between the wheels. Instead they use a washer and the washers are not a consistent thickness which is probably why the wheels crack.
  8. eddie1681
    eddie1681 New
    Good to know thank you
  9. antang808
    antang808 New
    If I am in the same position where I have the frame, router, and 4 NEMA23 motors and I just need the electronics to power/control the motors does that mean I would just need the blackbox, the power supply to it, and limit switches?
    Yip that will do. Refer to start [OpenBuilds Documentation]
  11. antang808
    antang808 New
    The blackbox has all the wiring I need, correct? One thing I noticed is that the blackbox only has 3 limit switches. Does that mean there only can be 3 instead of 6?
  12. Peter Van Der Walt
    The BlackBox (SKU2790) has connectors, but if you need wiring too, refer to either the Bundle (SKU2925) CNC Electronics Bundle instead
    or alternatively, refer to Electronics - Cables - OpenBuilds Part Store and Electronics - Connectors - OpenBuilds Part Store
    You can wire 6, just parallel up the second ones (SIG on controller, to SIG on first switch to SIG on second switch, repeat for GND and V+)
    #12 Peter Van Der Walt, Oct 28, 2020
  13. antang808
    antang808 New
    I'm sorry what does SIG mean? I understand that if its in parallel then if one switch turns on, the circuit will be complete but all cables look direct so is there a splitter cable?
  14. Peter Van Der Walt
    Signal. Limit switch connectors has 3 pins (you wire the connectors, its screw terminals. It is not premade "direct" cables)
    SIG = signal
    V+ = power
    GND = ground
    See docs:blackbox:connect-xtension-limit [OpenBuilds Documentation]
    You can wire two wires into one terminal hole to wire the second switch (in parallel)
    Or, skip the second of switches and use Soft Limits: See gnea/grbl
    Must-read bedtime reading tonight:
    - Read the whole Grbl Wiki gnea/grbl - every page - understand Grbl will help you immensely going forward
    - Skim through all the sections of the BlackBox Docs docs:blackbox:start [OpenBuilds Documentation] - so you know what it supports, what goes where etc
    - Watch the Youtube Videos relevant to your machine: https://www.youtube.com/user/OpenBuilds/search?query=wiring blackbox
