X axis Deviation Blackbox
Discussion in 'Controller Boards' started by Erik van Trijp, Oct 12, 2020.
  1. Erik van Trijp
    Hi all,
    I have an OX cnc, converted to plasma. Everything is working (almost) fine. I have a strange problem..
    I calibrated the axis, and they are spot on (100mm). Only a strange behavior with the X axis.
    When i tell it to cut 70mm, it does 65mm. Not once, but 10 times in a row on rectangle box.
    The Y is always spot on, tell it to cut 100mm, it does 100mm. Tell the X to cut 70mm, it does 65mm..
    Anyone has an idea?
    Greetings,
    Erik
    Mechanical: slipping pulley/shaft coupler on motor shaft, or something else loose
    Or
    Intermittent wiring break / loose terminal
