X axis reversed?
Discussion in 'General Talk' started by Steve Dean1977, Feb 29, 2020.
  1. Steve Dean1977
    If when I setup my job in aspire to cut it correctly I have to mirror it backwards like the photo is that my x axis reversed?
  2. Alex Chambers
    When you jog your X axis in the positive direction which way does it go - left or right?
  3. Steve Dean1977
    X- Goes to the left x+ right Y+ to back of machine Y- to the front
  4. Steve Dean1977
    When I say left and right Left is is if I was standing behind the machine looking to the open front
  5. Steve Dean1977
    iPad drawing
  6. TurboDan
    TurboDan New
    My C-Beam was the same. Change direction in GRBL Panel using $3 setting. Might be able to do same with your control software. Reversing wires of one of the coils is an option too.
  7. Steve Dean1977
    I can change the direction in the software but is that why my projects are reversed?
  8. TurboDan
    TurboDan New
    When I was doing dry run of "Hello World" file to verify movement, it looked reversed, but was not actually cutting anything so not 100% sure.
    Whatever the case, x-axis appears to be going in wrong direction according to your pic. Change and you will answer your question.
