X hanging up
Discussion in 'General Talk' started by William Harper, Jul 16, 2022.
  1. William Harper
    I have been using my Lead 1010 for quite some time. Now the X feed is hanging up. I have adjusted the wheels several times and it still is hanging up. each time it hangs its off by 1 inch. any help would be appreciated.
    Thanks.
  2. Alex Chambers
    Hi @William Harper, forgive me for being thick, could you explain what you mean by "the X feed is hanging up" - do you mean it's stalling? Is the motor stopping or the movement of the X gantry?
  3. William Harper
    Sorry for not being very clear. The X gantry stops the motor continues to try and move it.
  4. Alex Chambers
    If you (power off first) disconnect the motor from the leadscrew can you manually move the X gantry all the way across without any sign of binding? Does it always stop in the same place? Have you overtightened the nut blocks? (you should only tighten them to the gantry plates enough to stop them moving and after fixing the first one gently squeeze them together before tightening the second (the aim is to have each one touching one side of the thread, but not gripping tightly).
    PS, on a different topic, did you try to join the Facebook group Workbee CNC Users Group? If so could you please try again making sure that you answer the membership question and tick the box to agree to the rules.
  5. William Harper
    Thanks for the quick responses Alex. I did as you requested and there was no binding moving the gantry with my fingers. It will bind in different places while working. Sorry but I don't have a Facebook account
  6. William Harper
    Oh! it does this using Lightburn laser program
  7. Alex Chambers
    [QUOTE="William Harper, post: 126860, member: 66604" Sorry but I don't have a Facebook account[/QUOTE]
    Not a problem, just someone with the same name.
  8. Alex Chambers
    Does it do this while jogging, or only when running a job? If you are using lightburn what are your feedrates in lightburn , your max feedrate and acceleration settings in your controller config? (grbl settings if it's a grbl controller).
  9. Giarc
    It sounds like maybe too high of acceleration. The X is used at high speeds going back and forth for rastering which may be why it shows up using lightburn
    Alex Chambers likes this.
  10. William Harper
    Only while running job. max feed rate is 150 and it is a GRBL controller. it is moving fast but it will get a quarter of the job done then start binding.
  11. Peter Van Der Walt
    Not your JOB FEEDRATE.
    We mean the GRBL MAX FEEDRATE in Grbl Settings: This one: Grbl v1.1 Configuration · gnea/grbl Wiki
    Rapids (G0s) are run at Max, Cut moves (G1/2/3) will honor your Gcode feedrate
    Thus you have to make sure Max Rate is set low enough not to stall
    Post a backup of your Grbl Settings if you need us to check it for you. OpenBuildsCONTROL > Connect > Grbl Settings tab > Backup Settings button on top toolbar
    And what unit? mm/second or mm/minute?
  12. William Harper
    In Lightburn GRBL 120,121,122 rate is set at 700mm/sec. so I read this correctly I should slow this down until it stops binding! correct!
  13. Peter Van Der Walt
    Yes that's crazy: 42000mm/min after conversion
    Belt drives are usually around 10000mm/min, leadscrew more like 3500-5000mm/min
    Note that Grbl uses mm/min, Lightburn's mm/sec can cause unit confusion so stay aware of what unit you should be working in and multiply/divide by 60 as needed)
    So yes, lower it until it no longer stalls, but start nearer a proper ballpark figure first as shown above
    sharmstr and Alex Chambers like this.
  14. William Harper
    Thanks, Peter. Time to start adjusting and testing.
  15. David the swarfer
    could also be the X driver is overheating and cutting out.
