Now that I've completed to 'OX' build I'm stuck on the electrics. The xPro v.3 board is all lit up (see Attachments) except for the 'X' motor for some reason isn't connecting. All the wire are true as I went round and checked them individually and there are no breaks anywhere. The pairs are correct as they are the same for each motor. I paid special attention to them even pairing them separately and tying them off with a small plastic tie so they wouldn't get tangled up and slotted into the wrong holes. The Nema wires are Blue, Black, Red and green and the pairs are Black & Red, Green & Blue. I've even run the 'X' Nema 23 by its self to make sure it's not dead, but it ran as it did before I installed it on the machine. So I don't know what to do at present. The GRBL software says there's a connection on com 6 but no data is coming from it (see Attachment). Perhaps someone has experienced something similar and can tell me how to sort it. Thank's a lot.
The baud rate needs to be 115200, not 57600: Spark-Concepts/xPRO For the motor, here are some troubleshooting steps Spark-Concepts/xPRO
Thanks a lot for the reply. Wasn't sure about the baud rate and have now changed it to 115200 and I'm off to have a look at Spark-Concepts/xPRO Thanks again.
