x32 Controller issue with X-Axis stepper
Discussion in 'Controller Boards' started by Eric Harwood, Feb 2, 2025.
  1. Eric Harwood
    I have a 1010 machine with a X32 controller running grblHAL 1.1f.
    Machine has been working great, without issues, until yesterday. After running a job, I attempted to re-home the machine, and the X-Axis is functioning sporadically. I have attached 2 videos demonstrating the random weird behavior. At times, X-axis stepper will somewhat work (video #1) and other times, X-Axis stepper sounds like a grinding noise and refuses to move (video #2).
    Note: Y and Z axis steppers are properly moving without any issues.
    I have attempted to reset the X32 via (software/power cycle), to no avail. Again, machine ran a clean set of cuts, without issue, and then the problem appeared.
    EMI:
    1. I have removed all terminal plugs from the X32 motors and limit switches, and verified there are no loose wires. Everything is snug as a bug.
    2. I have no power wires crossing the motor wires, trying to seperate/isolate each to avoid excess EMI.
    3. I do have a SuperPID unit controlling the router. That is also properly grounded.
    - I also disconnected the SuperPID units power, and attempted a jog of the X-Axis, and still see the same results, even with this unit powered off.
    4. I restored my backed up grblHAL settings and reprogrammed the X32, however still see the issues.
    Could use some help.
    1. Is it a failed set of controller drivers on the X32?
    2. Bad NEMA 23 stepper (Using the OpenBuidls MT-2303H280AW-OB) stepper motors?
    3. other?
    Before I tear apart and redo all the wiring (which I'd rather not do), I wanted to see if anyone has some additional thoughts?
    Thanks,
    Eric
  2. Alex Chambers
    On my phone, so didn't look at the videos yet, but your description sounds very much like a loose/intermittent connection on one wire out of the four to that stepper. If you can't find a poor connection try using that stepper cable on the Z motor.
    IMPORTANT - Power off before disconnecting/reconnecting any wiring.
  3. Eric Harwood
    Alex:
    Good idea.. and I just tried that.
    Here's what I tried..
    0. Powered off the X32.
    1. Disconnected the X-Axis motor wires from the X-Axis motor port and reconnected the X-Axis Motor wires into the Z-Axis motor port, on the X32
    2. Connected the Z-Axis Motor Wires into the X-Axis motor port, on the X32.
    3. Powered on the X32 and reconnected via USB
    4. Using OpenBuildsCONTROL jog feature, hit the Z-Down/Z-Up buttons (to test X-Axis Stepper Motor).
    Results: Same Motor Behavior is seen in the videos. Barely moves and or makes a grind noise)
    5. Then I used the X-Left/Right jog buttons, to move the Z-Axis Stepper Motors (formally known to be working, as stated earlier)
    Results: Z-Axis stepper motors worked perfectly.
    Conclusion:
    - I believe this proves the X32 motor drivers are not bad (for the XYZ-Motor Ports)
    - I concure there is probably a Wiring issue with the X-Axis wiring to the Stepper, which I will replace next
    - If resoldering the new wiring doesnt resolve it, then I would assume were looking at a Stepper Motor issue itself
    Thoughts?
  4. Eric Harwood
    Prolem Resolved:
    The Fix:
    - Loose wire that fed into the terminal block that gets plugged into the X32.
    - Used a multi-meter to verify continuity on each side of the stepper motor. Using this method described in the troubleshooting section of the X32
    I was able to locate which specific wire was causing the problem.
    Many thanks to Alex for pointing me in the right direction! All X/Y/Z axis are now functioning as expected!
