X32 GCODE
Discussion in 'CNC Mills/Routers' started by Fastbass, Oct 31, 2024.
  1. Fastbass
    Fastbass New
    when programming a cam file does the cam program need to process gcode in MM or Inches for the x32? I am using deskproto multi axis and in the machine config it has options for GRBL(ardruino) - inch or GRBL(arduino)- MM. thanks in advance.
    Can use either, the gcode must just tell the controller what its in (G20 or G21 in gcode to match) which those posts will do for you
  3. Fastbass
    Fastbass New
    thanks peter
