xyx probe direction
Discussion in 'General Electronics' started by hickory43, Aug 19, 2024.
Tags:
  1. hickory43
    hickory43 New
    Hi All, I am using your x32 blackbox with your xyz probe. When using the probe with your control software the z moves to away from the probe instead of the top of the probe. Is there a way to control the probe direction?
  2. Jeff Richmond
    when using center as your start point set your xy zero and then place the probe there and probe for z only
    If your Z axis is reversed, correct it in Grbl Settings. Z+ should raise the tool off the stock, Z- should bring it toward the stock.
  4. hickory43
    hickory43 New
    Thanks for the reply. What are the grbl commands?
    CONTROL > Grbl Settings tab > $3 Direction Invert > Flip the Z Axis switch the other from where its now. Save and Reset when prompted
  6. hickory43
    hickory43 New
    Thanks for your help.
