XYZ Probe calibration
Discussion in 'CNC Mills/Routers' started by Tim Percy, Sep 20, 2021.
  1. Tim Percy
    Tim Percy Well-Known
    Is there any way to calibrate the OpenBuilds XYZ Probe? I find mine is off 0.01" on the Z. I was wondering why it was cutting into my spoilboard.
    #1 Tim Percy, Sep 20, 2021
    Probe type > Custom > Enter values
    However, they are quite precise. Cutting into your spoilboard could rather be:
    - Need to recalibrate Z axis: Wizard and tools menu > Calibration
    - Something loose in Z axis causing backlash
    - Spoilboard instability (temperature/moisture causes it to bow and stretch and move like any other piece of wood over time, if you resurface you will find high and low spots all the time
    - Accept that a spoil board is called a spoilboard because its meant to be spoiled :)
