XYZ probe issues
Discussion in 'General Electronics' started by Darklink594, Nov 7, 2022.
  1. Darklink594
    So I just got my machine up and going and I wanted to test out the xyz probe. It looks like the light comes on even when the probe isint touching the bit, could it be a grounding issue?
    Also I should mention I'm using the Blackbox and the openbuilds interface
    Almost certainly yes
    Disconnect that upside-down Z axis switch as a first test - if the issue goes away, flip the switch around so the bottom is on the rubber spacer - screw head could be grounding the Z axis - passing ground through the z axis to the spindle.
    If that wasn't it: See XYZ Probe Plus with VFDs and other ground-loop inducing components
