XYZ Probe offsets
Discussion in 'CNC Mills/Routers' started by Andre Malenfant, Nov 4, 2022.
  1. Andre Malenfant
    Is it possible to know the actual offsets of the official OB XYZ probe?
    Andre Malenfant likes this.
  3. Andre Malenfant
    Perfect response. Didn't think of looking at Control's source code. Thanks!
    A caliper across the actual probe would be even better - manufacturing and plating tolerances etc
  5. sharmstr
    ^^ THIS ^^^
  6. Andre Malenfant
    I don’t have it. I have a home made version and I wated to adjust the probe macro for the Interface.
    Well then set Probe Type to Custom and add your dimensions (calipers) :)
  8. Andre Malenfant
    On the Interface. Not CONTROL. The I needed to know the offset because the variable for x and y jn the macro has half the bit size + offset.
  9. Peter Van Der Walt
    Ok gotcha :)
