XYZ Probe Question
Discussion in 'General Talk' started by Charles Robey, Sep 7, 2022.
  1. Charles Robey
    When I first use the Probe, it works fine. After I change jobs and run the Probe Function, sometimes it works fine. Other times, it will zero and then move across the probe setting an alarm. Sometimes when I Z-probe, it will move across the top setting an alarm.
    Am I doing something wrong or what could be causing these problems?
    Any help is appreciated.
    Are you sure your version of CONTROL is up to date? V1.0.331
  3. David the swarfer
    what bits are you probing with?
    some coatings on bits are not conductive....
  4. Charles Robey
    I will check the Version and Update if needed.
    The Bits are Uncoated.
