XYZ Probe Stuck at Z
Discussion in 'CNC Mills/Routers' started by Wendel Clement, Apr 8, 2023.
  1. Wendel Clement
    New Installation, I have set up my XYZ Probe out of the box. But when I try to probe in the automatic mode it comes down on the Z, gives the green light and then gets stuck there. If I try the other mode it goes past the plate and starts going down into my material.
    I've check through the Forum but can't seem to see this scenario. I am running the X32 Controler all out of the box and being used for the first time.
    Any ideas?
    You need to update the firmware in the X32. Use OpenbuildsCONTROL to do it.
  3. Wendel Clement
    Thank you, will do.
    Step 7.1 of the BlackBox Documentation at https://docs.openbuilds.com/blackbox-x32
    If you did skip the docs, also make sure to see section 4.2 (another important step best followed)
