XYZ Probe
Discussion in 'CNC Mills/Routers' started by sjashe, Mar 17, 2025.
  1. sjashe
    sjashe New
    I am installing the XYZ probe on a Millwright machine that we drive using Openbuilds Control.
    When I connect the probe and ground lines, it works properly with the probe and z-probe macros, so we are using it.
    If I connect the 5V line, it just lights up and indicates "touched" immediately when the magnet is put on the collet. For now I'm leaving this unconnected.
    I am going to try swapping the probe plate with one I have at home to see if there is a problem with it.
    Any thoughts?
  3. sjashe
    sjashe New
    Thanks Peter..
    Its comforting to see you are still here responding to our questions.
    We are using a dewalt 618 on this one rather than the 611, via the iorelay. Do you think that router is not similar in grounding?
    It is working, but I'm getting a little OCD hoping to get the leds functioning.
    Router is double insulated, so not the issue then
    also if it works, not ground loop
    As for why adding the pull-up power triggers your controller - could ask your controller's manufacturer, or consider replacing that controller with a BlackBox X32? docs:blackbox-x32:start [OpenBuilds Documentation]
  5. sjashe
    sjashe New
    ha ha.. I was thinking the same thing on the black box. Its a makerspace, so we are eventually going to move up to a 4' x 4' unit.
    Im going to try swapping out the plate to be sure its not a short in there. then decide if it really matters and Im just too OCD right now
  6. sjashe
    sjashe New
    Interesting. I thought the signal input had a pullup, and closing the connection caused a level change to ground. Is it the opposite?
    Correct, thats what the probe does. SIG to GND normally for probe contact, V+ adds 10K pullup on signal line, and positive side of LEDs through resistor, so when negative of LED (sig) touches GND via contact, LEDs light - pretty simple
