Y axis motor does not move
Discussion in 'CNC Mills/Routers' started by fflen, Aug 23, 2024.
  1. fflen
    fflen New
    Still new at this any help will be appreciated. This is about the third time this week when I tried to jog or home the Y motor (left side) -Y it did not start just the Y2 motor ran. I have to disconnect from the controller and power down then it starts right up and runs fine. Also just noticed my power supply fan stop working. Y axis motor and power supply cold to the touch and Y2 barely warm.
    This is the first time I have operated thru the WIFI I don't think that matters but its information.
    1010 with plasma add on
    Black box 32
    Design and Cam on Fusion
    This error may just be a symptom of an earlier event:
    ALARM: 4 - Probe fail. The probe is not in the expected initial state before starting probe cycle, where G38.2 and G38.3 is not triggered and G38.4 and G38.5 is triggered.
    ALARM: 4 - Probe fail. The probe is not in the expected initial state before starting probe cycle, where G38.2 and G38.3 is not triggered and G38.4 and G38.5 is triggered.This error may just be a symptom of an earlier event:
    [11:56:02] [ ] $346=1 ;Restore position after M6 as boolean
    [11:56:02] [ ] $370=0 ;Invert I/O Port Inputs (mask)
    [11:56:02] [ ] $384=0 ;Disable G92 Persistence
    [11:56:02] [ ] $394=4.0 ;Spindle on delay in s, range: 0.5 - 20
    [11:56:02] [ ] $396=30 ;WebUI timeout in minutes
    [11:56:02] [ ] $397=0 ;WebUI auto report interval in milliseconds
    [11:56:02] [ ] $398=100 ;Planner buffer blocks
    [11:56:02] [ ] $481=0 ;Autoreport interval in ms
    [11:56:02] [ ] $484=1 ;Unlock required after E-Stop as boolean
    [11:56:02] [ ] $486=0 ;Lock coordinate systems as bitfield
    [11:56:02] [ ] $650=0 ;File systems options as bitfield
    [11:56:02] [ ] $673=1.0 ;Coolant on delay in s, range: 0.5 - 20
    [11:56:02] [ ] ok
    [11:56:02] [ $$ ] [VER:1.1f.20240402:leadmachine1010plasma]
    [11:56:02] [ $$ ] [OPT:VNASL2,100,1024,3,0]
    [11:56:02] [ $$ ] [AXS:3:XYZ]
    [11:56:02] [ $$ ] [NEWOPT:ENUMS,RT+,HOME,ES,REBOOT,SED,RTC,WIFI,SD]
    [11:56:02] [ $$ ] [FIRMWARE:grblHAL]
    [11:56:02] [ $$ ] [SIGNALS:HSEP]
    [11:56:02] [ $$ ] [NVS STORAGE:*FLASH]
    [11:56:02] [ $$ ] [FREE MEMORY:154K]
    [11:56:02] [ $$ ] [DRIVER:ESP32]
    [11:56:02] [ $$ ] [DRIVER VERSION:240330]
    [11:56:02] [ $$ ] [DRIVER OPTIONS:4.3.2]
    [11:56:02] [ $$ ] [BOARD:BlackBox X32]
    [11:56:02] [ $$ ] [AUX IO:2,0,0,0]
    [11:56:02] [ $$ ] [WIFI MAC:d4:d4:da:4d:b5:70]
    [11:56:02] [ $$ ] [IP:0.0.0.0]
    [11:56:02] [ $$ ] [PLUGIN:WebUI v0.21]
    [11:56:02] [ $$ ] [PLUGIN:SDCARD v1.13]
    [11:56:02] [ $$ ] [PLUGIN:FS macro plugin v0.07]
    [11:56:02] [ $$ ] ok
    [11:59:56] [ disconnect ] PORT INFO: Port closed
    [12:00:01] [ network ] Starting network scan for: 192.168.12.1-192.168.12.254
    [12:00:03] [ network ] Network Scan completed. Found 0 devices
    [12:00:03] [ network ports ] Detected a change in IP devices: [ No IP devices ]
    [12:00:17] [ network ] Starting network scan for: 192.168.12.1-192.168.12.254
    [12:00:19] [ network ] Network Scan completed. Found 0 devices
    [12:00:27] [ network ] Starting network scan for: 192.168.12.1-192.168.12.254
    [12:00:29] [ network ] Network Scan completed. Found 0 devices
    [12:00:37] [ network ] Starting network scan for: 192.168.12.1-192.168.12.254
    [12:00:39] [ network ] Network Scan completed. Found 1 devices. Network addresses added to the Port selection dropdown.
    [12:00:40] [ network ports ] Detected a change in IP devices: [192.168.12.194]
    [12:01:43] [ connect ] PORT INFO: Port is now open: COM6 - Attempting to detect Controller...
    [12:01:43] [ connect ] Attempting to detect Controller (1): (Autoreset)
    [12:01:43] [ ] ok
    [12:01:44] [ connect ] Attempting to detect Controller (2): (Ctrl+X)
    [12:01:44] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [12:01:46] [ $$ ] $0=10.0 ;Step pulse time, microseconds
    [12:01:46] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [12:01:46] [ $$ ] $2=0 ;Step pulse invert, mask
    [12:01:46] [ $$ ] $3=4 ;Step direction invert, mask
    [12:01:46] [ $$ ] $4=0 ;Invert step enable pin, boolean
    [12:01:46] [ $$ ] $5=7 ;Invert limit pins, boolean/mask
    [12:01:46] [ $$ ] $6=0 ;Invert probe pin, boolean
    [12:01:46] [ $$ ] $8=0 ;Ganged axes direction invert as bitfield
    [12:01:46] [ $$ ] $9=1 ;PWM Spindle as bitfield where setting bit 0 enables the rest
    [12:01:46] [ $$ ] $10=511 ;Status report options, mask
    [12:01:46] [ $$ ] $11=0.010 ;Junction deviation, millimeters
    [12:01:46] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [12:01:46] [ $$ ] $13=0 ;Report in inches, boolean
    [12:01:46] [ $$ ] $14=0 ;Invert control input signals, mask
    [12:01:46] [ $$ ] $15=0 ;Coolant pins invert, mask
    [12:01:46] [ $$ ] $16=0 ;Spindle pins invert, mask
    [12:01:46] [ $$ ] $17=0 ;Control pins pullup disable, mask
    [12:01:46] [ $$ ] $18=0 ;Limit pins pullup disable, mask
    [12:01:46] [ $$ ] $19=0 ;Probe pin pullup disable, boolean
    [12:01:46] [ $$ ] $20=0 ;Soft limits enable, boolean
    [12:01:46] [ $$ ] $21=1 ;Hard limits enable, boolean
    [12:01:46] [ $$ ] $22=1 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    [12:01:46] [ $$ ] $23=1 ;Homing direction invert, mask
    [12:01:46] [ $$ ] $24=100.0 ;Homing locate feed rate, mm/min
    [12:01:46] [ $$ ] $25=1500.0 ;Homing search seek rate, mm/min
    [12:01:46] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [12:01:46] [ $$ ] $27=7.000 ;Homing switch pull-off distance, millimeters
    [12:01:46] [ $$ ] $28=0.100 ;G73 retract distance, in mm
    [12:01:46] [ $$ ] $29=0.0 ;Step pulse delay (ms)
    [12:01:46] [ $$ ] $30=255.000 ;Maximum spindle speed, RPM
    [12:01:46] [ $$ ] $31=0.000 ;Minimum spindle speed, RPM
    [12:01:46] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [12:01:46] [ $$ ] $33=5000.0 ;Spindle PWM frequency
    [12:01:46] [ $$ ] $34=0.0 ;Spindle off Value
    [12:01:46] [ $$ ] $35=0.0 ;Spindle min value
    [12:01:46] [ $$ ] $36=100.0 ;Spindle max value
    [12:01:46] [ $$ ] $37=0 ;Stepper deenergize mask
    [12:01:46] [ $$ ] $39=1 ;Enable printable realtime command characters, boolean
    [12:01:46] [ $$ ] $40=0 ;Apply soft limits for jog commands, boolean
    [12:01:46] [ $$ ] $43=1 ;Homing passes
    [12:01:46] [ $$ ] $44=4 ;Homing cycle 1
    [12:01:46] [ $$ ] $45=3 ;Homing cycle 2
    [12:01:46] [ $$ ] $46=0 ;Homing cycle 3
    [12:01:46] [ $$ ] $62=0 ;Sleep Enable
    [12:01:46] [ $$ ] $63=3 ;Feed Hold Actions
    [12:01:46] [ $$ ] $64=0 ;Force Init Alarm
    [12:01:46] [ $$ ] $65=1 ;Require homing sequence to be executed at startup
    [12:01:46] [ $$ ] $70=7 ;Network Services
    [12:01:46] [ $$ ] $73=1 ;Wifi Mode
    [12:01:46] [ $$ ] $74=TMOBILE-B338 ;Wifi network SSID
    [12:01:46] [ $$ ] $75=mycarisa1966GTO ;Wifi network PSK
    [12:01:46] [ $$ ] $100=199.11000 ;X-axis steps per millimeter
    [12:01:47] [ $$ ] $101=199.22999 ;Y-axis steps per millimeter
    [12:01:47] [ $$ ] $102=198.56999 ;Z-axis steps per millimeter
    [12:01:47] [ $$ ] $110=3800.000 ;X-axis maximum rate, mm/min
    [12:01:47] [ $$ ] $111=3800.000 ;Y-axis maximum rate, mm/min
    [12:01:47] [ $$ ] $112=1500.000 ;Z-axis maximum rate, mm/min
    [12:01:47] [ $$ ] $120=500.000 ;X-axis acceleration, mm/sec^2
    [12:01:47] [ $$ ] $121=500.000 ;Y-axis acceleration, mm/sec^2
    [12:01:47] [ $$ ] $122=500.000 ;Z-axis acceleration, mm/sec^2
    [12:01:47] [ $$ ] $130=500.000 ;X-axis maximum travel, millimeters
    [12:01:47] [ $$ ] $131=520.000 ;Y-axis maximum travel, millimeters
    [12:01:47] [ $$ ] $132=35.000 ;Z-axis maximum travel, millimeters
    [12:01:47] [ $$ ] $320=grblHAL ;Hostname, max: 64
    [12:01:47] [ $$ ] $322=192.168.5.1 ;IP Address
    [12:01:47] [ $$ ] $323=192.168.5.1 ;Gateway
    [12:01:47] [ $$ ] $324=255.255.255.0 ;Netmask
    [12:01:47] [ $$ ] $325=23 ;Telnet port
    [12:01:47] [ $$ ] $326=80 ;HTTP port
    [12:01:47] [ $$ ] $327=81 ;Websocket port
    [12:01:47] [ $$ ] $337= ;WiFi Access Point (AP) BSSID
    [12:01:47] [ $$ ] $341=0 ;Tool Change Mode
    [12:01:47] [ $$ ] $342=25.0 ;Tool Change probing distance
    [12:01:47] [ $$ ] $343=30.0 ;Tool Change Locate Feed rate
    [12:01:47] [ $$ ] $344=400.0 ;Tool Change Search Seek rate
    [12:01:47] [ $$ ] $345=400.0 ;Tool Change Probe Pull Off rate
    [12:01:47] [ $$ ] $346=1 ;Restore position after M6 as boolean
    [12:01:47] [ $$ ] $370=0 ;Invert I/O Port Inputs (mask)
    [12:01:47] [ $$ ] $384=0 ;Disable G92 Persistence
    [12:01:47] [ $$ ] $394=4.0 ;Spindle on delay in s, range: 0.5 - 20
    [12:01:47] [ $$ ] $396=30 ;WebUI timeout in minutes
    [12:01:47] [ $$ ] $397=0 ;WebUI auto report interval in milliseconds
    [12:01:47] [ $$ ] $398=100 ;Planner buffer blocks
    [12:01:47] [ $$ ] $481=0 ;Autoreport interval in ms
    [12:01:47] [ $$ ] $484=1 ;Unlock required after E-Stop as boolean
    [12:01:47] [ $$ ] $486=0 ;Lock coordinate systems as bitfield
    [12:01:47] [ $$ ] $650=0 ;File systems options as bitfield
    [12:01:47] [ $$ ] $673=1.0 ;Coolant on delay in s, range: 0.5 - 20
    [12:01:47] [ $$ ] ok
    [12:01:47] [ $I ] [VER:1.1f.20240402:leadmachine1010plasma]
    [12:01:47] [ $I ] [OPT:VNASL2,100,1024,3,0]
    [12:01:47] [ $I ] [AXS:3:XYZ]
    [12:01:47] [ $I ] [NEWOPT:ENUMS,RT+,HOME,ES,REBOOT,SED,RTC,WIFI,SD]
    [12:01:47] [ $I ] [FIRMWARE:grblHAL]
    [12:01:47] [ $I ] [SIGNALS:HSEP]
    [12:01:47] [ $I ] [NVS STORAGE:*FLASH]
    [12:01:47] [ $I ] [FREE MEMORY:153K]
    [12:01:47] [ $I ] [DRIVER:ESP32]
    [12:01:47] [ $I ] [DRIVER VERSION:240330]
    [12:01:47] [ $I ] [DRIVER OPTIONS:4.3.2]
    [12:01:47] [ $I ] [BOARD:BlackBox X32]
    [12:01:47] [ $I ] [AUX IO:2,0,0,0]
    [12:01:47] [ $I ] [WIFI MAC:d4:d4:da:4d:b5:70]
    [12:01:47] [ $I ] [IP:192.168.12.194]
    [12:01:47] [ $I ] [PLUGIN:WebUI v0.21]
    [12:01:47] [ $I ] [PLUGIN:SDCARD v1.13]
    [12:01:47] [ $I ] [PLUGIN:FS macro plugin v0.07]
    [12:01:47] [ $I ] ok
    [12:01:47] [ $G ] [GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
    [12:01:47] [ $G ] ok
    [12:01:47] [ connect ] Firmware Detected: grblHAL version 1.1f dated on COM6
    [12:04:11] [ disconnect ] PORT INFO: Port closed
    [12:04:12] [ usb ports ] Detected a change in available ports: [COM5][COM4]
    [12:04:27] [ network ] Starting network scan for: 192.168.12.1-192.168.12.254
    [12:04:29] [ network ] Network Scan completed. Found 1 devices. Network addresses added to the Port selection dropdown.
    [12:04:47] [ connect ] PORT INFO: Port is now open: undefined - Attempting to detect Controller...
    [12:04:47] [ connect ] Attempting to detect Controller (1): (Autoreset)
    [12:04:47] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [12:04:47] [ ] ok
    [12:04:50] [ $$ ] $0=10.0 ;Step pulse time, microseconds
    [12:04:50] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [12:04:50] [ $$ ] $2=0 ;Step pulse invert, mask
    [12:04:50] [ $$ ] $3=4 ;Step direction invert, mask
    [12:04:50] [ $$ ] $4=0 ;Invert step enable pin, boolean
    [12:04:50] [ $$ ] $5=7 ;Invert limit pins, boolean/mask
    [12:04:50] [ $$ ] $6=0 ;Invert probe pin, boolean
    [12:04:50] [ $$ ] $8=0 ;Ganged axes direction invert as bitfield
    [12:04:50] [ $$ ] $9=1 ;PWM Spindle as bitfield where setting bit 0 enables the rest
    [12:04:50] [ $$ ] $10=511 ;Status report options, mask
    [12:04:50] [ $$ ] $11=0.010 ;Junction deviation, millimeters
    [12:04:50] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [12:04:50] [ $$ ] $13=0 ;Report in inches, boolean
    [12:04:50] [ $$ ] $14=0 ;Invert control input signals, mask
    [12:04:50] [ $$ ] $15=0 ;Coolant pins invert, mask
    [12:04:50] [ $$ ] $16=0 ;Spindle pins invert, mask
    [12:04:50] [ $$ ] $17=0 ;Control pins pullup disable, mask
    [12:04:50] [ $$ ] $18=0 ;Limit pins pullup disable, mask
    [12:04:50] [ $$ ] $19=0 ;Probe pin pullup disable, boolean
    [12:04:50] [ $$ ] $20=0 ;Soft limits enable, boolean
    [12:04:50] [ $$ ] $21=1 ;Hard limits enable, boolean
    [12:04:50] [ $$ ] $22=1 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    [12:04:50] [ $$ ] $23=1 ;Homing direction invert, mask
    [12:04:50] [ $$ ] $24=100.0 ;Homing locate feed rate, mm/min
    [12:04:50] [ $$ ] $25=1500.0 ;Homing search seek rate, mm/min
    [12:04:50] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [12:04:50] [ $$ ] $27=7.000 ;Homing switch pull-off distance, millimeters
    [12:04:50] [ $$ ] $28=0.100 ;G73 retract distance, in mm
    [12:04:50] [ $$ ] $29=0.0 ;Step pulse delay (ms)
    [12:04:50] [ $$ ] $30=255.000 ;Maximum spindle speed, RPM
    [12:04:50] [ $$ ] $31=0.000 ;Minimum spindle speed, RPM
    [12:04:50] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [12:04:50] [ $$ ] $33=5000.0 ;Spindle PWM frequency
    [12:04:50] [ $$ ] $34=0.0 ;Spindle off Value
    [12:04:50] [ $$ ] $35=0.0 ;Spindle min value
    [12:04:50] [ $$ ] $36=100.0 ;Spindle max value
    [12:04:50] [ $$ ] $37=0 ;Stepper deenergize mask
    [12:04:50] [ $$ ] $39=1 ;Enable printable realtime command characters, boolean
    [12:04:50] [ $$ ] $40=0 ;Apply soft limits for jog commands, boolean
    [12:04:51] [ $$ ] $43=1 ;Homing passes
    [12:04:51] [ $$ ] $44=4 ;Homing cycle 1
    [12:04:51] [ $$ ] $45=3 ;Homing cycle 2
    [12:04:51] [ $$ ] $46=0 ;Homing cycle 3
    [12:04:51] [ $$ ] $62=0 ;Sleep Enable
    [12:04:51] [ $$ ] $63=3 ;Feed Hold Actions
    [12:04:51] [ $$ ] $64=0 ;Force Init Alarm
    [12:04:51] [ $$ ] $65=1 ;Require homing sequence to be executed at startup
    [12:04:51] [ $$ ] $70=7 ;Network Services
    [12:04:51] [ $$ ] $73=1 ;Wifi Mode
    [12:04:51] [ $$ ] $74=TMOBILE-B338 ;Wifi network SSID
    [12:04:51] [ $$ ] $75=mycarisa1966GTO ;Wifi network PSK
    [12:04:51] [ $$ ] $100=199.11000 ;X-axis steps per millimeter
    [12:04:51] [ $$ ] $101=199.22999 ;Y-axis steps per millimeter
    [12:04:51] [ $$ ] $102=198.56999 ;Z-axis steps per millimeter
    [12:04:51] [ $$ ] $110=3800.000 ;X-axis maximum rate, mm/min
    [12:04:51] [ $$ ] $111=3800.000 ;Y-axis maximum rate, mm/min
    [12:04:51] [ $$ ] $112=1500.000 ;Z-axis maximum rate, mm/min
    [12:04:51] [ $$ ] $120=500.000 ;X-axis acceleration, mm/sec^2
    [12:04:51] [ $$ ] $121=500.000 ;Y-axis acceleration, mm/sec^2
    [12:04:51] [ $$ ] $122=500.000 ;Z-axis acceleration, mm/sec^2
    [12:04:51] [ $$ ] $130=500.000 ;X-axis maximum travel, millimeters
    [12:04:51] [ $$ ] $131=520.000 ;Y-axis maximum travel, millimeters
    [12:04:51] [ $$ ] $132=35.000 ;Z-axis maximum travel, millimeters
    [12:04:51] [ $$ ] $320=grblHAL ;Hostname, max: 64
    [12:04:51] [ $$ ] $322=192.168.5.1 ;IP Address
    [12:04:51] [ $$ ] $323=192.168.5.1 ;Gateway
    [12:04:51] [ $$ ] $324=255.255.255.0 ;Netmask
    [12:04:51] [ $$ ] $325=23 ;Telnet port
    [12:04:51] [ $$ ] $326=80 ;HTTP port
    [12:04:51] [ $$ ] $327=81 ;Websocket port
    [12:04:51] [ $$ ] $337= ;WiFi Access Point (AP) BSSID
    [12:04:51] [ $$ ] $341=0 ;Tool Change Mode
    [12:04:51] [ $$ ] $342=25.0 ;Tool Change probing distance
    [12:04:51] [ $$ ] $343=30.0 ;Tool Change Locate Feed rate
    [12:04:51] [ $$ ] $344=400.0 ;Tool Change Search Seek rate
    [12:04:51] [ $$ ] $345=400.0 ;Tool Change Probe Pull Off rate
    [12:04:51] [ $$ ] $346=1 ;Restore position after M6 as boolean
    [12:04:51] [ $$ ] $370=0 ;Invert I/O Port Inputs (mask)
    [12:04:51] [ $$ ] $384=0 ;Disable G92 Persistence
    [12:04:51] [ $$ ] $394=4.0 ;Spindle on delay in s, range: 0.5 - 20
    [12:04:51] [ $$ ] $396=30 ;WebUI timeout in minutes
    [12:04:51] [ $$ ] $397=0 ;WebUI auto report interval in milliseconds
    [12:04:52] [ $$ ] $398=100 ;Planner buffer blocks
    [12:04:52] [ $$ ] $481=0 ;Autoreport interval in ms
    [12:04:52] [ $$ ] $484=1 ;Unlock required after E-Stop as boolean
    [12:04:52] [ $$ ] $486=0 ;Lock coordinate systems as bitfield
    [12:04:52] [ $$ ] $650=0 ;File systems options as bitfield
    [12:04:52] [ $$ ] $673=1.0 ;Coolant on delay in s, range: 0.5 - 20
    [12:04:52] [ $$ ] ok
    [12:04:52] [ connect ] Firmware Detected: grblHAL version 1.1f dated on 192.168.12.194
    [12:04:52] [ $I ] [VER:1.1f.20240402:leadmachine1010plasma]
    [12:04:52] [ $I ] [OPT:VNASL2,100,1024,3,0]
    [12:04:52] [ $I ] [AXS:3:XYZ]
    [12:04:52] [ $I ] [NEWOPT:ENUMS,RT+,HOME,ES,REBOOT,SED,RTC,WIFI,SD]
    [12:04:52] [ $I ] [FIRMWARE:grblHAL]
    [12:04:52] [ $I ] [SIGNALS:HSEP]
    [12:04:52] [ $I ] [NVS STORAGE:*FLASH]
    [12:04:52] [ $I ] [FREE MEMORY:153K]
    [12:04:52] [ $I ] [DRIVER:ESP32]
    [12:04:52] [ $I ] [DRIVER VERSION:240330]
    [12:04:52] [ $I ] [DRIVER OPTIONS:4.3.2]
    [12:04:52] [ $I ] [BOARD:BlackBox X32]
    [12:04:52] [ $I ] [AUX IO:2,0,0,0]
    [12:04:52] [ $I ] [WIFI MAC:d4:d4:da:4d:b5:70]
    [12:04:52] [ $I ] [IP:192.168.12.194]
    [12:04:52] [ $I ] [NETCON:Telnet]
    [12:04:52] [ $I ] [PLUGIN:WebUI v0.21]
    [12:04:52] [ $I ] [PLUGIN:SDCARD v1.13]
    [12:04:52] [ $I ] [PLUGIN:FS macro plugin v0.07]
    [12:04:52] [ $I ] ok
    [12:04:52] [ $G ] [GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
    [12:04:52] [ $G ] ok
    [12:05:00] [ $J=G91G21Z1F1200 ] ok
    [12:05:01] [ $J=G91G21Z1F1200 ] ok
    [12:05:04] [ $J=G91G21Z1F1200 ] ok
    [12:05:07] [ $J=G91G21Z1F1200 ] ok
    [12:05:08] [ $J=G91G21Z1F1200 ] ok
    [12:05:42] [ $J=G91G21Z1F1200 ] ok
    [12:05:43] [ $J=G91G21Z1F1200 ] ok
    [12:06:13] [ $J=G91 G21 Y1000 F3040 ] ok
    [12:06:16] [ $J=G91 G21 Y-1000 F3040 ] ok
    [12:06:17] [ $J=G91 G21 Y-1000 F3040 ] ok
    [12:06:36] [ ALARM ] ALARM: 6 - Homing fail. Reset during active homing cycle. [ undefined ]
    [12:06:36] [ ] ALARM: 6 - Homing fail. Reset during active homing cycle. [ undefined ]
    [12:06:36] [ ] ALARM:6
    [12:06:36] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [12:06:36] [ ] [MSG:'$H'|'$X' to unlock]
    [12:06:38] [ [clear alarm] ] Operator clicked Clear Alarm: Cleared Lockout and Emptied Queue
    [12:06:38] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [12:06:38] [ ] [MSG:'$H'|'$X' to unlock]
    [12:06:39] [ ] [MSG:Caution: Unlocked]
    [12:06:39] [ ] ok
    [12:06:40] [ $J=G91 G21 Y-1000 F3040 ] ok
    #1 fflen, Aug 23, 2024
    See docs:blackbox-x32:currentadjustment [OpenBuilds Documentation]
    Keep an eye out, does the Fault LED for that axis light up when it stops working? Power cycling resets the FAULT condition, so by that description from you, it sounds like its likely the cause
  3. fflen
    fflen New
    I'll definitely check for the LED light, but this happens when I first start up so its not because of heat. It gets a little scary when the X axis gets a little twisted. I turn everything off and then calibrate both the Y motors to the gantry. I'll have to read up on the motor calibration.
    Thank you
    Would still happen if its overcurrent, read the link I shared - multiple causes for fault, not just heat... Turn it down a bit
  5. fflen
    fflen New
    I do get a red led. So the red light only comes on when its overcurrent. Before reading your last post I turned it up just a little and the light when right out, but after reading your last post I'll turn it back down and see what happens.
