Y-Motor Issue
Discussion in 'CNC Mills/Routers' started by Charles Robey, Jul 9, 2022.
  1. Charles Robey
    I connected my Black Box today. Using Open Builds Control Software, I was able to move my Y axis fine. I found the Connector for my Z axis was loose, connected my z and it worked fine. At this point all my axis' were operating. I switched my Z axis direction and now my Y axis only has one motor running. I have checked the Connections and they look fine. Any ideas as to what it might be?
    Any help is appreciated.
    1) is the Fault LED on the front lit for that axis?
    If so see docs.openbuilds.com > BlackBox > Current adjustment
    2) otherwise, most likely wiring. See the Identifying motor coils / Troubleshooting section of docs.openbuilds.com/blackbox
