Z-Axis crashes when starting a job using Blackbox X4 and Touch Interface
Discussion in 'Control Software' started by maddinek, Mar 14, 2023.
  1. maddinek
    maddinek New
    Hello everyone,
    I have been facing an issue with my CNC machine (Lead 1010) when using G-code generated by Fusion360. Every time I try to run the G-code using an USB stick on the Interface, the machine makes the same initial movements. Specifically, the Z-axis moves downwards and heads towards the starting point, resulting in a collision with the board if the bit is left on.
    I'm using the XYZ Touch Probe Plus for the calibration of the zero point.
    I have tried various solutions but have not been successful in resolving this issue. I would appreciate any advice or suggestions on how to fix this problem.
    Thank you in advance!
    WCS offset is set to 1
    Stock Point is set to the upper corner of the starting point.
    In another thread I found someone checking the EndPos: Use Machine Coordinates (G53) but the result is the same with or without.
    Code:
    (Made in : Autodesk CAM Post Processor)
    (G-Code optimized for Grbl 1.1 / BlackBox controller)
    (OpenBuilds CNC : GRBL/BlackBox)
    (Post-Processor : OpenbuildsFusion360PostGrbl.cps V1.0.33)
    (Units = mm)
    (Drawing name : test2 v5)
    (Program Name : 1001)
    (1 Operation :)
    (1 : 2D Contour5)
    (  Work Coordinate System : G54)
    (  Tool 5: Flat End Mill 2 Flutes, Diam = 4mm, Len = 22.00mm)
    (  Spindle : RPM = 24000)
    (  Machining time : 10 min 8 sec)
    G90 G94 G17
    G21
    (When using Fusion 360 for Personal Use, the feedrate of)
    (rapid moves is reduced to match the feedrate of cutting)
    (moves, which can increase machining time. Unrestricted rapid)
    (moves are available with a Fusion 360 Subscription.)
    (Operation 1 of 1 : 2D Contour5)
    G54
    (This relies on homing, see https://openbuilds.com/search/127200199/?q=G53+fusion )
    G53 G0 Z-10
    G0 X1.504 Y771
    S24000 M3
    G4 P1.8
    G0 X1.504 Y771 Z10 F1920
    G1 Z5
    Z3 F1350
    Z-2
    G2 X-1.364 Y774.882 I0 J3 F1920
    X69.364 Y753.118 I35.364 J-10.882
    X-1.363 Y753.118 I-35.364 J10.882
    X1.504 Y757 I2.867 J0.882
    G1 X14.5
    Y771
    X1.504
    Z-4 F1350
    G1 X14.5
    Y771
    X1.504
    Z-6 F1350
    G1 X14.5
    Y771
    X1.504
    Z-8 F1350
    G1 X14.5
    Y771
    X1.504
    Z-10 F1350
    G1 X14.5
    Y771
    X1.504
    Z-12 F1350
    G1 X14.5
    Y771
    X1.504
    Z-14 F1350
    G1 X14.5
    Y771
    X1.504
    Z-16 F1350
    X60.405 Y738.081 I-35.364 J10.882
    X60.087 Y737.761 Z-15.1 I-26.405 J25.919
    X57.102 Y735.098 I-26.087 J26.239
    X56.748 Y734.819 Z-16 I-23.102 J28.902 F1350
    X13.903 Y732.934 I-22.748 J29.181 F1920
    X13.525 Y733.181 Z-15.1 I20.097 J31.066
    X10.318 Y735.572 I20.475 J30.819
    X9.974 Y735.862 Z-16 I23.682 J28.428 F1350
    X-1.363 Y753.118 I24.026 J28.138 F1920
    G1 X14.5
    Y771
    X1.504
    Z-17.05 F1350
    X60.771 Y738.459 I-35.364 J10.882
    X60.087 Y737.761 Z-15.1 I-26.771 J25.541
    X56.331 Y734.498 Z-17.05 I-23.102 J28.902 F1350
    X14.347 Y732.651 I-22.331 J29.502 F1920
    X13.525 Y733.181 Z-15.1 I19.653 J31.349
    X9.576 Y736.207 Z-17.05 I23.682 J28.428 F1350
    X-1.363 Y753.118 I24.424 J27.793 F1920
    G1 X14.5
    Y771
    X1.504
    Z-18.1 F1350
    X61.132 Y738.843 I-35.364 J10.882
    X60.087 Y737.761 Z-15.1 I-27.132 J25.157
    X55.908 Y734.183 Z-18.1 I-23.102 J28.902 F1350
    X14.795 Y732.375 I-21.908 J29.817 F1920
    X13.525 Y733.181 Z-15.1 I19.205 J31.625
    X9.182 Y736.558 Z-18.1 I23.682 J28.428 F1350
    X-1.363 Y753.118 I24.818 J27.442 F1920
    G1 X14.5
    Y771
    X1.504
    G0 Z10
    G1 X84.86 Y756.51
    Z5
    Z3 F1350
    Z-2
    G2 X86.504 Y757 I1.644 J-2.51 F1920
    G1 X99.5
    Y771
    X86.504
    G2 X83.637 Y774.882 I0 J3
    X154.363 Y753.118 I35.363 J-10.882
    X83.637 Y753.118 I-35.363 J10.882
    X84.86 Y756.51 I2.867 J0.882
    G0 Z10
    G1 X86.504 Y757
    Z5
    Z1 F1350
    Z-4
    X99.5 F1920
    Y771
    X86.504
    X86.504 Y757 I2.867 J0.882
    G1 Z-6 F1350
    X99.5 F1920
    Y771
    X86.504
    G1 Z-8 F1350
    X99.5 F1920
    Y771
    X86.504
    G1 Z-10 F1350
    X99.5 F1920
    Y771
    X86.504
    G1 Z-12 F1350
    X99.5 F1920
    Y771
    X86.504
    G1 Z-14 F1350
    X99.5 F1920
    Y771
    X86.504
    G1 Z-16 F1350
    X99.5 F1920
    Y771
    X86.504
    X142.534 Y735.45 I-35.363 J10.882
    X142.185 Y735.165 Z-15.1 I-23.534 J28.55
    X138.936 Y732.831 I-23.185 J28.835
    X138.555 Y732.59 Z-16 I-19.936 J31.169 F1350
    X98.903 Y732.934 I-19.555 J31.41 F1920
    X98.525 Y733.181 Z-15.1 I20.097 J31.066
    X95.318 Y735.572 I20.475 J30.819
    X94.974 Y735.862 Z-16 I23.682 J28.428 F1350
    X83.637 Y753.118 I24.026 J28.138 F1920
    G1 Z-17.05 F1350
    X99.5 F1920
    Y771
    X86.504
    X142.938 Y735.787 I-35.363 J10.882
    X142.185 Y735.165 Z-15.1 I-23.938 J28.213
    X138.106 Y732.315 Z-17.05 I-19.936 J31.169 F1350
    X99.347 Y732.651 I-19.106 J31.685 F1920
    X98.525 Y733.181 Z-15.1 I19.653 J31.349
    X94.576 Y736.207 Z-17.05 I23.682 J28.428 F1350
    X83.637 Y753.118 I24.424 J27.793 F1920
    G1 Z-18.1 F1350
    X99.5 F1920
    Y771
    X86.504
    X143.338 Y736.131 I-35.363 J10.882
    X142.185 Y735.165 Z-15.1 I-24.338 J27.869
    X137.653 Y732.046 Z-18.1 I-19.936 J31.169 F1350
    X99.795 Y732.375 I-18.653 J31.954 F1920
    X98.525 Y733.181 Z-15.1 I19.205 J31.625
    X94.182 Y736.558 Z-18.1 I23.682 J28.428 F1350
    X83.637 Y753.118 I24.818 J27.442 F1920
    G0 Z10
    G1 X174.424 Y771.839
    Z5
    Z3 F1350
    Z-2
    G2 X173.636 Y774.882 I2.08 J2.162 F1920
    X244.364 Y753.118 I35.364 J-10.882
    X173.636 Y753.118 I-35.364 J10.882
    X176.504 Y757 I2.867 J0.882
    G1 X189.5
    Y771
    X176.504
    G2 X174.424 Y771.839 I0 J3
    G1 Z-4 F1350
    G1 X189.5
    Y771
    X176.504
    G1 Z-6 F1350
    G1 X189.5
    Y771
    X176.504
    G1 Z-8 F1350
    G1 X189.5
    Y771
    X176.504
    G1 Z-10 F1350
    G1 X189.5
    Y771
    X176.504
    G1 Z-12 F1350
    G1 X189.5
    Y771
    X176.504
    G1 Z-14 F1350
    G1 X189.5
    Y771
    X176.504
    G1 Z-16 F1350
    X235.405 Y738.081 I-35.364 J10.882
    X235.087 Y737.761 Z-15.1 I-26.405 J25.919
    X232.102 Y735.098 I-26.087 J26.239
    X231.748 Y734.819 Z-16 I-23.102 J28.902 F1350
    X192.279 Y730.994 I-22.748 J29.181 F1920
    X191.878 Y731.2 Z-15.1 I16.721 J33.006
    X188.437 Y733.24 I17.122 J32.8
    X188.064 Y733.493 Z-16 I20.563 J30.76 F1350
    X173.636 Y753.118 I20.936 J30.507 F1920
    G1 X189.5
    Y771
    X176.504
    G1 Z-17.05 F1350
    X235.771 Y738.459 I-35.364 J10.882
    X235.087 Y737.761 Z-15.1 I-26.771 J25.541
    X231.331 Y734.498 Z-17.05 I-23.102 J28.902 F1350
    X192.75 Y730.759 I-22.331 J29.502 F1920
    X191.878 Y731.2 Z-15.1 I16.25 J33.241
    X187.632 Y733.794 Z-17.05 I20.563 J30.76 F1350
    X173.636 Y753.118 I21.368 J30.206 F1920
    G1 X189.5
    Y771
    X176.504
    G1 Z-18.1 F1350
    X236.132 Y738.843 I-35.364 J10.882
    X235.087 Y737.761 Z-15.1 I-27.132 J25.157
    X230.908 Y734.183 Z-18.1 I-23.102 J28.902 F1350
    X193.225 Y730.531 I-21.908 J29.817 F1920
    X191.878 Y731.2 Z-15.1 I15.775 J33.469
    X187.204 Y734.101 Z-18.1 I20.563 J30.76 F1350
    X173.636 Y753.118 I21.796 J29.899 F1920
    G1 X189.5
    Y771
    X176.504
    G0 Z10
    G1 X259.86 Y771.49
    Z5
    Z3 F1350
    Z-2
    G2 X258.636 Y774.882 I1.644 J2.51 F1920
    X329.364 Y753.118 I35.364 J-10.882
    X258.636 Y753.118 I-35.364 J10.882
    X261.504 Y757 I2.867 J0.882
    G1 X274.5
    Y771
    X261.504
    G2 X259.86 Y771.49 I0 J3
    G1 Z-4 F1350
    G1 X274.5
    Y771
    X261.504
    G1 Z-6 F1350
    G1 X274.5
    Y771
    X261.504
    G1 Z-8 F1350
    G1 X274.5
    Y771
    X261.504
    G1 Z-10 F1350
    G1 X274.5
    Y771
    X261.504
    G1 Z-12 F1350
    G1 X274.5
    Y771
    X261.504
    G1 Z-14 F1350
    G1 X274.5
    Y771
    X261.504
    G1 Z-16 F1350
    X320.405 Y738.081 I-35.364 J10.882
    X320.087 Y737.761 Z-15.1 I-26.405 J25.919
    X317.102 Y735.098 I-26.087 J26.239
    X316.748 Y734.819 Z-16 I-23.102 J28.902 F1350
    X273.903 Y732.934 I-22.748 J29.181 F1920
    X273.526 Y733.181 Z-15.1 I20.097 J31.066
    X270.318 Y735.572 I20.474 J30.819
    X269.974 Y735.862 Z-16 I23.682 J28.428 F1350
    X258.636 Y753.118 I24.026 J28.138 F1920
    G1 X274.5
    Y771
    X261.504
    G1 Z-17.05 F1350
    X320.771 Y738.459 I-35.364 J10.882
    X320.087 Y737.761 Z-15.1 I-26.771 J25.541
    X316.331 Y734.498 Z-17.05 I-23.102 J28.902 F1350
    X274.347 Y732.651 I-22.331 J29.502 F1920
    X273.526 Y733.181 Z-15.1 I19.653 J31.349
    X269.576 Y736.207 Z-17.05 I23.682 J28.428 F1350
    X258.636 Y753.118 I24.424 J27.793 F1920
    G1 X274.5
    Y771
    X261.504
    G1 Z-18.1 F1350
    X321.132 Y738.843 I-35.364 J10.882
    X320.087 Y737.761 Z-15.1 I-27.132 J25.157
    X315.908 Y734.183 Z-18.1 I-23.102 J28.902 F1350
    X274.795 Y732.375 I-21.908 J29.817 F1920
    X273.526 Y733.181 Z-15.1 I19.205 J31.625
    X269.182 Y736.558 Z-18.1 I23.682 J28.428 F1350
    X258.636 Y753.118 I24.818 J27.442 F1920
    G1 X274.5
    Y771
    X261.504
    G0 Z10
    G1 X349.424 Y771.839
    Z5
    Z3 F1350
    Z-2
    G2 X348.636 Y774.882 I2.08 J2.162 F1920
    X419.364 Y753.118 I35.364 J-10.882
    X348.636 Y753.118 I-35.364 J10.882
    X351.504 Y757 I2.867 J0.882
    G1 X364.5
    Y771
    X351.504
    G2 X349.424 Y771.839 I0 J3
    G1 Z-4 F1350
    G1 X364.5
    Y771
    X351.504
    G1 Z-6 F1350
    G1 X364.5
    Y771
    X351.504
    G1 Z-8 F1350
    G1 X364.5
    Y771
    X351.504
    G1 Z-10 F1350
    G1 X364.5
    Y771
    X351.504
    G1 Z-12 F1350
    G1 X364.5
    Y771
    X351.504
    G1 Z-14 F1350
    G1 X364.5
    Y771
    X351.504
    G1 Z-16 F1350
    X407.534 Y735.449 I-35.364 J10.882
    X407.185 Y735.165 Z-15.1 I-23.534 J28.551
    X403.937 Y732.831 I-23.185 J28.835
    X403.555 Y732.59 Z-16 I-19.937 J31.169 F1350
    X367.279 Y730.994 I-19.555 J31.41 F1920
    X366.878 Y731.2 Z-15.1 I16.721 J33.006
    X363.437 Y733.24 I17.122 J32.8
    X363.064 Y733.493 Z-16 I20.563 J30.76 F1350
    X348.636 Y753.118 I20.936 J30.507 F1920
    G1 X364.5
    Y771
    X351.504
    G1 Z-17.05 F1350
    X407.938 Y735.787 I-35.364 J10.882
    X407.185 Y735.165 Z-15.1 I-23.938 J28.213
    X403.106 Y732.315 Z-17.05 I-19.937 J31.169 F1350
    X367.75 Y730.759 I-19.106 J31.685 F1920
    X366.878 Y731.2 Z-15.1 I16.25 J33.241
    X362.632 Y733.794 Z-17.05 I20.563 J30.76 F1350
    X348.636 Y753.118 I21.368 J30.206 F1920
    G1 X364.5
    Y771
    X351.504
    G1 Z-18.1 F1350
    X408.338 Y736.131 I-35.364 J10.882
    X407.185 Y735.165 Z-15.1 I-24.338 J27.869
    X402.653 Y732.046 Z-18.1 I-19.937 J31.169 F1350
    X368.225 Y730.531 I-18.653 J31.954 F1920
    X366.878 Y731.2 Z-15.1 I15.775 J33.469
    X362.204 Y734.101 Z-18.1 I20.563 J30.76 F1350
    X348.636 Y753.118 I21.796 J29.899 F1920
    G1 X364.5
    Y771
    X351.504
    G0 Z10
    G1 X439.424
    Z5
    Z3 F1350
    Z-2
    G2 X438.636 Y774.882 I2.08 J2.162 F1920
    X509.364 Y753.118 I35.364 J-10.882
    X438.636 Y753.118 I-35.364 J10.882
    X441.504 Y757 I2.867 J0.882
    G1 X454.5
    Y771
    X441.504
    G2 X439.424 Y771.839 I0 J3
    G1 Z-4 F1350
    G1 X454.5
    Y771
    X441.504
    G1 Z-6 F1350
    G1 X454.5
    Y771
    X441.504
    G1 Z-8 F1350
    G1 X454.5
    Y771
    X441.504
    G1 Z-10 F1350
    G1 X454.5
    Y771
    X441.504
    G1 Z-12 F1350
    G1 X454.5
    Y771
    X441.504
    G1 Z-14 F1350
    G1 X454.5
    Y771
    X441.504
    G1 Z-16 F1350
    X500.405 Y738.081 I-35.364 J10.882
    X500.087 Y737.761 Z-15.1 I-26.405 J25.919
    X497.102 Y735.098 I-26.087 J26.239
    X496.748 Y734.819 Z-16 I-23.102 J28.902 F1350
    X457.279 Y730.994 I-22.748 J29.181 F1920
    X456.878 Y731.2 Z-15.1 I16.721 J33.006
    X453.437 Y733.24 I17.122 J32.8
    X453.064 Y733.493 Z-16 I20.563 J30.76 F1350
    X438.636 Y753.118 I20.936 J30.507 F1920
    G1 X454.5
    Y771
    X441.504
    G1 Z-17.05 F1350
    X500.771 Y738.459 I-35.364 J10.882
    X500.087 Y737.761 Z-15.1 I-26.771 J25.541
    X496.331 Y734.498 Z-17.05 I-23.102 J28.902 F1350
    X457.75 Y730.759 I-22.331 J29.502 F1920
    X456.878 Y731.2 Z-15.1 I16.25 J33.241
    X452.632 Y733.794 Z-17.05 I20.563 J30.76 F1350
    X438.636 Y753.118 I21.368 J30.206 F1920
    G1 X454.5
    Y771
    X441.504
    G1 Z-18.1 F1350
    X501.132 Y738.843 I-35.364 J10.882
    X500.087 Y737.761 Z-15.1 I-27.132 J25.157
    X495.908 Y734.183 Z-18.1 I-23.102 J28.902 F1350
    X458.225 Y730.531 I-21.908 J29.817 F1920
    X456.878 Y731.2 Z-15.1 I15.775 J33.469
    X452.204 Y734.101 Z-18.1 I20.563 J30.76 F1350
    X438.636 Y753.118 I21.796 J29.899 F1920
    G1 X454.5
    Y771
    X441.504
    G0 Z10
    G1 X529.424
    Z5
    Z3 F1350
    Z-2
    G2 X528.636 Y774.882 I2.08 J2.162 F1920
    X599.364 Y753.118 I35.364 J-10.882
    X528.636 Y753.118 I-35.364 J10.882
    X531.504 Y757 I2.867 J0.882
    G1 X544.5
    Y771
    X531.504
    G2 X529.424 Y771.839 I0 J3
    G1 Z-4 F1350
    G1 X544.5
    Y771
    X531.504
    G1 Z-6 F1350
    G1 X544.5
    Y771
    X531.504
    G1 Z-8 F1350
    G1 X544.5
    Y771
    X531.504
    G1 Z-10 F1350
    G1 X544.5
    Y771
    X531.504
    G1 Z-12 F1350
    G1 X544.5
    Y771
    X531.504
    G1 Z-14 F1350
    G1 X544.5
    Y771
    X531.504
    G1 Z-16 F1350
    X590.405 Y738.081 I-35.364 J10.882
    X590.087 Y737.761 Z-15.1 I-26.405 J25.919
    X587.102 Y735.098 I-26.087 J26.239
    X586.748 Y734.819 Z-16 I-23.102 J28.902 F1350
    X547.279 Y730.994 I-22.748 J29.181 F1920
    X546.878 Y731.2 Z-15.1 I16.721 J33.006
    X543.437 Y733.24 I17.122 J32.8
    X543.064 Y733.493 Z-16 I20.563 J30.76 F1350
    X528.636 Y753.118 I20.936 J30.507 F1920
    G1 X544.5
    Y771
    X531.504
    G1 Z-17.05 F1350
    X590.771 Y738.459 I-35.364 J10.882
    X590.087 Y737.761 Z-15.1 I-26.771 J25.541
    X586.331 Y734.498 Z-17.05 I-23.102 J28.902 F1350
    X547.75 Y730.759 I-22.331 J29.502 F1920
    X546.878 Y731.2 Z-15.1 I16.25 J33.241
    X542.632 Y733.794 Z-17.05 I20.563 J30.76 F1350
    X528.636 Y753.118 I21.368 J30.206 F1920
    G1 X544.5
    Y771
    X531.504
    G1 Z-18.1 F1350
    X591.132 Y738.843 I-35.364 J10.882
    X590.087 Y737.761 Z-15.1 I-27.132 J25.157
    X585.908 Y734.183 Z-18.1 I-23.102 J28.902 F1350
    X548.225 Y730.531 I-21.908 J29.817 F1920
    X546.878 Y731.2 Z-15.1 I15.775 J33.469
    X542.204 Y734.101 Z-18.1 I20.563 J30.76 F1350
    X528.636 Y753.118 I21.796 J29.899 F1920
    G1 X544.5
    Y771
    X531.504
    G0 Z10
    G53 G0 Z-10
    M5
    G53 G0 X-10 Y-10
    M30
  2. Alex Chambers
    Are you homing your machine first? - the post processor uses the machine co-ordinate system for safety moves at the start and end of the job, if you don't home the machine the controller will think the position the machine was in when you switched on is the home position.
  3. maddinek
    maddinek New
    Hi Alex!
    Thanks for your response! I think you hit the nail, since "Home All axis" is greyed out. Will figure that out and post an update afterwards :)
    Thanks!
    Alex Chambers likes this.
  4. David the swarfer
    There are 2 ways to home
    with switches, and the home button does the job
    or 'fake the home' How to 'Fake the home'
    and why
    Home, Fusion360 and G53 Z moves
    There is a comment inside the Gcode about this (-:
  5. maddinek
    maddinek New
    Hi guys,
    I had to load the Lead 1010 profile and then I set the home. I did a test and it works like a charm.
    I will have a read. Thanks! I've got switches but I think I damaged on of them and I'm not sure if it might stop working at some point. Hence, it might be useful to set a fake home at some point.
    Thanks a lot guys! Finally, I can cut some toys for my kid! Worked days to figure that one out and you guys solved it in minutes! Appreciate it!
    Best :)
