Z-axis Deep Plunge
Discussion in 'CNC Mills/Routers' started by ricklach, Aug 5, 2021.
  1. ricklach
    ricklach Well-Known
    I was about to cutout some parts in aluminum. I homed the machine, then did a probe. I set the 1/4 in. bit for a max of .0625 in. pass depth and 20% chip load. When I ran the job the bit plunged into the materiel about .125 inches or more and then stalled. I checked all the parameters and tried running the job several times but with similar results. Can anyone suggest a solution to this issue.
  2. BKramer
    BKramer New
    Sounds like a work coordinate problem. Do you have homing on? If you do, home the machine first, then set your WCS, then try agin.
  3. Christian James
    Christian James Journeyman
    Did you probe off the bed? If so, have you got the correct material thickness in the set up page?
    What do you mean 20% chip load?
  4. David the swarfer
    Where is your origin for the setup in Fusion360? Top of material or bottom of material?
    Post the files if you don't know what I am asking.
  5. ricklach
    ricklach Well-Known
    Here are the first few lines of the gcode for the job - I can see no problem with them especially the first Z axis coordinate where the cut starts:
    T1
    G17
    G20
    G90
    G0Z0.2600
    G0X0.0000Y0.0000
    M3S10000
    G4 P1.8
    G0X7.6533Y3.3194Z0.2500
    G1Z0.0000F10.0
    G1X7.6444Y3.5161Z-0.0572
    G1X7.6356Y3.7128F15.0
    G1X7.6267Y3.9095
    G1X7.6178Y4.1062
    G1X7.6090Y4.3029
    G1X7.6001Y4.4996
    G1X7.5913Y4.6963
    G1X7.5824Y4.8930
    G1X7.4481Y7.8754
    G1X7.4286Y8.3076
    G1X7.4272Y8.3500
    G1X7.4269Y8.3749
    G1X7.4267Y8.3927
    G2X9.2817Y10.2469I1.8550J-0.0008
    G2X11.1367Y8.3927I0.0000J-1.8550
    G1X11.1362Y8.3500
    G1X11.1348Y8.3076
    G1X11.1171Y7.9153
    G1X11.0946Y7.4158
    G1X10.9101Y3.3194
    G1X10.9077Y3.2779
    G1X10.9045Y3.2377
    G1X10.9002Y3.1977
    G1X10.8950Y3.1581
  6. ricklach
    ricklach Well-Known
    Turns out the piece of aluminum plate that I was using had a slight bow in it - enough to cause the problem. I set Z-zero at the high spot and managed to manufacture my piece. Thanks for the assistance
  7. David the swarfer
    This is not Gcode form the OB postprocessor, the default Fusion post for GRBL is a bit broken, that is why we created our own.
    How to install it.
    The only real requirement is that Z is homed to Z+ limit. if you have limit switches then always homing after machine start is enough, otherwise you need to fake the home
