Z-axis driving me bonkers
Discussion in 'CNC Mills/Routers' started by mrhall4, Nov 10, 2022.
  1. mrhall4
    mrhall4 New
    Hey there,
    I'm not sure whats going on. But this morning I started a cut, following the same steps as always but for some reason my z-axis raises to the limit switch and then trips. Stopping the cut.
    My Steps.
    1. Post .nc from fusion 360
    2. Home machine
    3. Set zero using probe
    4. Start cut
    I have uploaded the .nc
    Thougths?
    Line 14 uses G28.
    We'd strongly recommend you use OUR post docs:software:fusion360 [OpenBuilds Documentation] which uses Machine Coordinates (much less complicated that using G28 coordinate system for safe moves). Instead ours simply require you to HOME (which you should anyway do). Also a tonne of other improvements - best to use our Post
  3. mrhall4
    mrhall4 New
    I mustve posted the wrong file. I changed it after multiple failed attempts. I am using this post and have always been using G54
  4. mrhall4
    mrhall4 New
    Or maybe I'm an idiot and I am using the wrong post all of a sudden. Will check back in 20 mins.
  5. sharmstr
    Its clear that it wasnt generated using the OB fusion post processor. Look at the header
    The OB header has the post name and version.
  6. mrhall4
    mrhall4 New
    ok, so I don't know how it happened but the machine setup did get changed somehow.
    Which is weird. I had to reinstall fusion this week but it made 3 good cuts before z-ing out before the cut today.
    I have fixed it in the machine library and the first cut seems to be working.
    Thank you. Its been a stressful morning and in my haste I was obviously was being dumb.
