Z axis not homing/ going up
Discussion in 'CNC Mills/Routers' started by Lapocat89, May 22, 2024.
  1. Lapocat89
    Lapocat89 New
    Hello! im am having trouble with the Z axis, it goes all well while it carves, but at the end of the job it does not go up and out of the way to homing but it stays at the depth of the gcode file and cuts right
    through
    1) Include the GCODE
    2) Tell us what CAM you are using
    The machine just follows your gcode, so wherever you are generating the gcode, its configured incorrectly
  3. Lapocat89
    Lapocat89 New
    i am using easel pro
    You gcode goes to Z +3.81mm above zero at the end of the job before it goes to XY0
    If you zero on top of the stock this should be safely above it.
    Are you sure Z is calibrated? Are you seeing any stall in Z (mechanical slip, or acceleration/max rate set too high, or spindle too heavy)
  5. Lapocat89
    Lapocat89 New
    Z goes up and down smoothly when carving, if i move it when it is not running a carve i have to lower the jog rate or it slips. Should i lower the feed rate when it terminates a carve and goes to home? where can i do that?
    Acceleration or Max rate too high: Grbl v1.1 Configuration
    G0 Moves follow the Max Rate not whatever feedrate you set for G1/2/3
    Quoted from the Grbl Wiki
    And the line it fails at is a G0
    Could also be acceleration too high: Grbl v1.1 Configuration
  7. Lapocat89
    Lapocat89 New
    I lowered the speed and acceleration rates for le z axis and it goes up and down with no problems now, but it does not come up when running a job or at job done, what else should i check ?
    I also tried carving free hand with the jog toggles anche the z axis goes up and down with no problems
    #7 Lapocat89, May 23, 2024
  8. David the swarfer
    slow it down more (half the maxrate, and half the accdeleration), the jog is not at full speed, but G0 moves are at full speed, and clearly that is failing to lift the weight of the router,
    now do a movement test, NOT jog, opent he serial console and issue real commands
    zero Z about 25mm above the spoil board
    give the commands
    G21 G90
    G0 Z-15
    G0 Z15
    that will move down 15mm and then move up by 30mm to Z15.
    if that succeeds then Gcode will succeed.
    Alex Chambers likes this.
