Z Axis Problem
Discussion in 'OpenBuilds Forum Help' started by Bobbolink, Mar 21, 2025.
  1. Bobbolink
    Bobbolink New
    I am having a problem with the router engaging the material after having set the Z Axis to zero. The machine runs fine , goes home, goes to zero, goes through the motion of the router running the part but I cannot get it to raise or lower beyond the Z zero setting. Checked the wires even replaced the wiring with new wiring to the Z Axis motor. I even recalibrated the Z Axis distance thinking it might be that. That did not help either. The only place I can think it might be is in the Glbr sequence. Been trying to fix the problem for about 3 days now. Ran out of ideas, thought maybe you guys may be able to enlighten me.
  2. Alex Chambers
    What cam software are you using? Do post your g-code file so we can look at it. Also, what controller are you using? - if a grbl one post your grbl settings.
  3. Bobbolink
    Bobbolink New
  4. Bobbolink
    Bobbolink New
    I am not a computer whiz been trying to figure out how to send info to you, best i come up with is shift print screen?
  5. Bobbolink
    Bobbolink New
  6. Bobbolink
    Bobbolink New
    Found Grbl backup file tried to upload it to you hope it works
    Also remember the gcode file @Bobbolink
  8. David the swarfer
    When you are typing a message, use the 'upload a file' button at bottom right to attach a fie, either text or picture.
    You can also drag and drop pictures onto the message.
  9. Bobbolink
    Bobbolink New
    Hopefully this is the G-code you want
  10. David the swarfer
    thankyou.
    That is code generated for a laser cutter
    Code:
    ; GCODE Generated bY- cam.openbuilds.com on 2025-03-24
    G21 ; mm-mode
    ; Created bY- OpenBuilds CAM
    G54; Work Coordinates
    G21; mm-mode
    G90; Absolute Positioning
    M4; DY-namic Power Laser On
    M4; DY-namic Power Laser On is only used for laser cutters.
    then a few lines later is tells it to go to Z0, which is just in contact with the surface of the material, and then it goes below that by only 0.094mm, not really far enough to be seen.
    If you have enabled 'soft limits' then turn it off now.
    Go into CAM and remove the existing toolpaths and replace them with milling paths rather than laser cuts, regenerate the Gcode.
    Let's just be clear on the correct sequence for running a job (besides choosing milling operations in CAM, rather than laser)
    1 - power up the machine
    2 - power up the computer and start OpenBuildsCONTROL
    3 - click the 'Home All' button so that the machine can find home , everything needs a sense of home Home, Fusion360 and G53 Z moves
    4 - load the Gcode file
    5 - jog to the material 0,0,0 point and click the relevant setZero buttons to teach the machine where 0 is for this part, this must match whatever was used in the CAM for the origin
    6 - jog Z up a little and start the router (unless the controller can turn it on via Gcode)
    7 - click 'Run Job' button
    with soft limits off and a proper home sequence, and also the correct Gcode, all should be well, but if it is not, we will need details...
    Alex Chambers likes this.
  11. Bobbolink
    Bobbolink New
    I have used both M3 and M4 for the code does not change laser nor router operation. The machine is zero for home works great, even set the z operation and it goes above the part x,y, function works the z command does not engage to cut the part out.
    I use the cam program and select the operation for CNC no options it generates the code. The router is manual switch operated.
    I will reset the GrblHal code on the soft limit see if it effects the Z operation.
    G54; Work Coordinate. Is on the machine selection setting, mine is a workbee 1510 with no other info following G54.
  12. Bobbolink
    Bobbolink New
    Nope no change. My question is why the program does not see and obey the Z command. It sees the X, Y, commands but not the Z settings.
  13. Alex Chambers
    These are your Z commands - none of the commands in your g-code file go any lower than this, and your Z safe move is only to Z0 - presumably to the surface of the material if that is where you set Z zero. You are in mm mode, so your maximum (only) plunge is 0.094 of a mm.
    I'm pretty sure this is a cad/cam problem, so please talk us through how you created the g-code file - what software you used etc.
    PS, I believe @David the swarfer was saying that the M4 line was an indication that the g-code file was created for a laser, not that M4 was the whole problem.
    #13 Alex Chambers, Mar 25, 2025
  14. Peter Van Der Walt
    Check your toolpath parameters in cam workflow, you as operator set the depths in the toolpath
  15. Peter Van Der Walt
    No that would indicate he has wrong tools set in CAM's settings (ticked Laser, instead of Router)
  16. Bobbolink
    Bobbolink New
    Software is openbuilds, my machine is a work bee 1510,
    Cam: open drawing: Select All: Create Toolpath: (For some reason it flashes unknown error Lasstused then goes away)
    Configure Toolpath: Select Operation: CNC Vector (No Offset)
    The settings are: Endmill/Pen Diameter 3.12 mm: Z Safe Height 0 mm; Spindle RPM 1000 rpm: Cut Depth 3 mm: Cut Depth per Pass 3 mm: Feed Rate (X/Y) 150 mm/min: Feed Rate Plunge -0.1 mm/min.
    Advance Settings: (Which I don't change): Cutting Direction: Climb: Geometry Merge No: Plunge: Ramp in (beta) Experimental No: Cut Depth Start 0 mm: Tabs Height 6 mm Tabs Spacing 50 mm;
    Select Apply and Preview Toolpath
    Generate G-Code
    Save G-Code (save goes to download file)
    Open File
    Set the zero to part and change the X Y to the direction -X -Y and the depth setting
    That's it.
  17. Peter Van Der Walt
    NB NB NB DONT DO THIS BEFORE PROVIDING REVIEWS, AS CLEARING LOCAL STORAGE WILL ALSO REMOVE ANY INCORRECT VALUES YOU HAVE IN TOOLPATH SETTINGS. JUST PROVIDING THIS INFO IF AFTERWARDS YOU WANT TO FIX LASTUSED ERROR
    Click Factory Reset to clear corrupted LastUsed from your browser's localstorage
    Not what the gcode you uploaded reflects.
    Provide screenshots or even better Project Export rather than typing out what you have
    We can import the saved project and check what you have set, so best way to review.
  18. Bobbolink
    Bobbolink New
    On the G-Code 3mm setting I tried entering my depth number -0.094 it did not like it. It likes the whole number -1.000 or greater. ?? don't know why it won't except -0.000 entries.
  19. Peter Van Der Walt
    Negative Depth? :) - how do you propose it will ADD material?
    Enter positive numbers. I want to cut "3mm" deep after all (not I want to Cut negative 3mm deep)
    Also, thats very very little distance, you won't see a 0.1mm move with the naked eye :)
    Average depth per pass is around 1/2 the endmill's diameter, doubt thats a 0.2mm endmill? What is the plan there
  20. Bobbolink
    Bobbolink New
    The material I cut is 1/8 thick the -0.094 setting is the final depth just before the getting into table. if I place the negative number into Cam final depth cut, it does not compile the job, so that is why I left it set at 3 mm in Cam. Hope this makes sense. I added the work file, the X, Y, Z depth and S settings are not edited.
  21. Peter Van Der Walt
    Positive speed for plunge as well please, can't move at negative speeds yet, time travel still not invented. Plus, think what you are typing. 0.1mm in per minute! - no man you can't move that slow...
    Correct it won't compile... you want to do a through cut of material?
    Its 1/8 inch = 3.175mm (for Final Cut Depth)...
    at
    some depth per pass (+-1/2 of 1/8" endmill, somewhere like 1.5-1.8mm depth per pass will do - call it 1.8mm per pass will do for woods, acrylics etc)
    Other issues:
    - missing Z safe height... got to lift that tool between cuts
    - feedrate insanely low - use proper feedrates
    - stop trying to use negative numbers
    - no offset is probably wrong too, looking at the CAD file I would have suspected inside cut for the holes and outside cut for the profile.
    Should be more like that (feedrate thumbsucked, not sure what material you have - refer speeds and feeds charts)
  22. Bobbolink
    Bobbolink New
    I do have a question regarding this machine. Do you think I could cut 3/4 thick aluminum material with it. Thought about getting a heavier milling machine but if this machine is capable i will use it.
  23. Alex Chambers
    Yes, a workbee is capable of cutting 3/4" aluminium, but you do need to take into account that the bit is going to be sticking out at least a little more than that. Forces on the bit will cause it to deflect and may cause chatter. I would recommend leaving approximately 0.02" of stock (cut it oversize) for a final finishing path and restricting depth of cut to approx 0.02".
  24. Bobbolink
    Bobbolink New
    Thank you for the information, I have been wondering about that for quite a while.
  25. Bobbolink
    Bobbolink New
    Thought I would follow up on the Z axis let you know I have it working sort of. I did the factory reset and had to do the custom machine set as there is not a 1510 work bee anymore (it is now obsolete). Had to reset zero settings and home settings. Z axis zero is now the table level setting any positive number above the table setting is the cutting option until the bit is lifted off the part. Completely backwards to what I was use to cutting at. It is working though. Been under the weather for the last few days so I am happy the Z axis is working.
  26. David the swarfer
    Z home is at the top of travel, all cuts are/should be moving negative from there.
    When you set part zero (setZeroZ button) at the top of the material, your display shows 0 at the surface , positive numbers for above the material and negative numbers for cutting.
    what does this mean?
    The Z axis limit switch triggers when Z is at the top end of travel. (safely up and away from the table, material, clamps etc)
    Jogging z+ moves Z upward. achieve this by adjusting the $3 'Step direction invert, mask'
    after that is correct, you adjust the 'homing direction invert mask' (variable $23) so that it homes toward the switch.
    Same process for the X and Y, X+ moves tool to the right
    Y+ moves tool away.
    a better explanation here Home, Fusion360 and G53 Z moves
  27. Alex Chambers
    You can use the Lead 1510 profile as a starting point, and then tweak settings as @David the swarfer said above. You might also have to adjust maximum axis dimensions ($130, 131 & 132) slightly - after you have calibarted your steps/mm.
  28. Bobbolink
    Bobbolink New
    In trouble again? Turn on computer brought the machine up as usual the machine would not recognize a different job, kept trying to run previous job from last night? So I tried to restore the backup set the machine settings but now control board has grayed out stop job and the home buttons . Shut down computer brought it back up same thing?
  29. David the swarfer
    loading a new job should be as simple as clicking the 'load gcode' button and selecting the file you want.
    so, if that is not possible, please describe in detail exactly what is happening that is preventing you loading a different gcode file.
  30. Bobbolink
    Bobbolink New
    Right now the machine buttons stop and home button is grayed out can't home. This occurred after I did a restore backup.
