Z-Axis problems
Discussion in 'CNC Mills/Routers' started by RasVelt, Dec 14, 2021.
  1. RasVelt
    RasVelt New
    Z axis jogs in the right direction, but candles doesn’t show depth & Z axis in visualizer points wrong direction. everything worked fine until I got a new control board. Please help
    What control board are you using
    Sure its flashed with standard Grbl?
  3. RasVelt
    RasVelt New
  4. Alex Chambers
    What machine are you using that controller with? And especially, what are the specs of your stepper motors? That is not a very good controller for a cnc machine - recommended maximum current 1.5 amps/motor.
    You would probably be much better getting the Openbuilds blackbox (just to be clear - I am an unpaid, volunteer moderator here - I get no benefits from recommending Openbuilds stuff, so that is unbiased advice) - and get a decent power supply to go with it.
  5. RasVelt
    RasVelt New
    VEVOR CNC 3018 CNC Router Kit 3 Axis CNC Router
    #5 RasVelt, Dec 15, 2021
    Alex Chambers likes this.
  7. RasVelt
    RasVelt New
  8. RasVelt
    RasVelt New
    It was a simple software setting I got it working. Thanks for the sales pitch
