z axis wont go up
Discussion in 'OpenBuilds Bug Report' started by cabrasauce, Sep 9, 2024.
  1. cabrasauce
    z axis goes down fine but then it can only go up about a quarter inch before it make a grinding noise and it wont go up any further. I checked a post saying check the wiring and
    "Grubscrews on shaft coupler rattled loose causing mechanical slippage when working harder to lift the Z axis"
    but they seem fine.
    I'm trying to move it by hand back to the top with the motor removed but am unsuccessful so I can look at the bottom half of the screw.
  3. cabrasauce
    found it, it was actually a screw that had backed out and would push against the rail going upward but not down.
