z axis
Discussion in 'CNC Mills/Routers' started by BRIAN TYLER, May 27, 2023.
  1. BRIAN TYLER
    the z axis is moving in the wrong direction, I swapped it to the x axis and it moves in the correct direction. How do I fix this?
  2. Alex Chambers
    What controller are you using? If it's a grbl controller the easiest way is to use Openbuilds Control - go to the grbl settings tab and invert the Z axis direction.
    The harder way, but will give you more insight into how grbl configuration works is to read the section on $3 in the link below.
    grbl/settings.md at master ยท gnea/grbl
    Giarc likes this.
