Z gantry loose
Discussion in 'General Talk' started by Arthur pells, Feb 8, 2023.
  1. Arthur pells
    There are off set nuts on the right hand side three in total that can be turned to tighten up any slack in the extreme V wheels, but there is no more adjustment left and there’s a small bit of play and the extreme V wheels are not tight does anybody have any tricks to fix this problem, I was thinking about getting some steel wheels machined, the same as the extreme wheels because I believe the extreme wheels have sunk into the track of the Z gantry
    You can post some pictures of your wheels if you'd like us to check - if there were adjusted beyond spec they can crack/degrade. Eccentrics should only be adjusted to dial out any free play - adjusting beyond that can cause damage to the wheels over time.
    Steel wheels would be a very bad idea - would ruin the extrusions (you'd want the hard faced extrusion to be the non-wear item, and the cheaper and easier to replace wheels should be the long term consumable)
  3. Arthur pells
  4. Arthur pells
    OK, thank you I think I will replace the wheels because right now I do have a heavier router and I have had some mishaps where the tool dug too deep while moving which may have caused some of the slop. My machine is only a couple of months old so I don’t think there will be any degrading just maybe a bit too much weight
  5. Arthur pells
    Would the extreme solid V wheels be a better choice or is that what is on her now?
    The Xtreme Solid V-Wheel is the best load carrying wheel yes.
    You don't say which machine you have? But if you are only using 4 wheels - most plates in our range allows for use of more (6 for example) to handle heavier loads.
  7. Arthur pells
    Lead 1515 6 wheels I’m going to order 15 nice to have spares
