Z-Probe wizard freezes - firmware will not flash.
Discussion in 'OpenBuilds Forum Help' started by FredStein, May 15, 2023.
  1. FredStein
    FredStein New
    Hi All,
    X-32 (Configured as a lightly customised Workbee 1510)
    CONTROL v1.0.638
    firmware grblHAL 1.1f
    I am having the same issues identified in this thread: https://openbuilds.com/threads/openbuilds-xyz-probe-not-working
    Everything else working fine.
    I have read section 7.1 / 7.2
    The solution seems to be to update the firmware, all good.
    I run the Firmware Flashing Tool with settings:
    * X32
    * FTDI USB to Serial COM5
    * 2/3 Axes CNC/Laser: Dual Y
    I get:
    [ disconnect ] PORT INFO: Port closed
    [ Firmware Upgrade ] connected
    [ Firmware Upgrade ] reset complete.
    [ Firmware Upgrade ] flashing, please wait...
    [ Firmware Upgrade ] FLASH FAILED!
    How do I overcome the FLASH FAILED! issue?
    Any advice gratefully received.
    The software is running on an up to date W11 laptop (Ryzen 9 5900HX)
    grbl settings on connect are:
    [13:02:00] [ connect ] PORT INFO: Port is now open: COM5 - Attempting to detect Firmware
    [13:02:00] [ connect ] Checking for firmware on COM5
    [13:02:00] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [13:02:00] [ ] ok
    [13:02:01] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [13:02:01] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [13:02:03] [ $$ ] $0=10.0 ;Step pulse time, microseconds
    [13:02:03] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [13:02:03] [ $$ ] $2=0 ;Step pulse invert, mask
    [13:02:03] [ $$ ] $3=0 ;Step direction invert, mask
    [13:02:03] [ $$ ] $4=0 ;Invert step enable pin, boolean
    [13:02:03] [ $$ ] $5=7 ;Invert limit pins, boolean/mask
    [13:02:03] [ $$ ] $6=1 ;Invert probe pin, boolean
    [13:02:03] [ $$ ] $7=0 ;Disable spindle with 0 speed, boolean
    [13:02:03] [ $$ ] $8=0 ;Ganged axes direction invert as bitfield
    [13:02:03] [ $$ ] $10=511 ;Status report options, mask
    [13:02:03] [ $$ ] $11=0.020 ;Junction deviation, millimeters
    [13:02:03] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [13:02:03] [ $$ ] $13=0 ;Report in inches, boolean
    [13:02:03] [ $$ ] $14=0 ;Limit pins invert, mask
    [13:02:03] [ $$ ] $15=0 ;Coolant pins invert, mask
    [13:02:03] [ $$ ] $16=0 ;Spindle pins invert, mask
    [13:02:03] [ $$ ] $17=0 ;Control pins pullup disable, mask
    [13:02:03] [ $$ ] $18=0 ;Limit pins pullup disable, mask
    [13:02:03] [ $$ ] $19=0 ;Probe pin pullup disable, boolean
    [13:02:03] [ $$ ] $20=0 ;Soft limits enable, boolean
    [13:02:03] [ $$ ] $21=1 ;Hard limits enable, boolean
    [13:02:03] [ $$ ] $22=1 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    [13:02:03] [ $$ ] $23=3 ;Homing direction invert, mask
    [13:02:03] [ $$ ] $24=150.0 ;Homing locate feed rate, mm/min
    [13:02:03] [ $$ ] $25=2500.0 ;Homing search seek rate, mm/min
    [13:02:03] [ $$ ] $26=25 ;Homing switch debounce delay, milliseconds
    [13:02:03] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
    [13:02:03] [ $$ ] $28=0.000 ;G73 retract distance, in mm
    [13:02:03] [ $$ ] $29=0.0 ;Step pulse delay (ms)
    [13:02:03] [ $$ ] $30=24000.000 ;Maximum spindle speed, RPM
    [13:02:03] [ $$ ] $31=0.000 ;Minimum spindle speed, RPM
    [13:02:03] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [13:02:03] [ $$ ] $33=5000.0 ;Spindle PWM frequency
    [13:02:03] [ $$ ] $34=0.0 ;Spindle off Value
    [13:02:03] [ $$ ] $35=0.0 ;Spindle min value
    [13:02:03] [ $$ ] $36=100.0 ;Spindle max value
    [13:02:03] [ $$ ] $37=0 ;Stepper deenergize mask
    [13:02:03] [ $$ ] $39=1 ;Enable printable realtime command characters, boolean
    [13:02:03] [ $$ ] $40=0 ;Apply soft limits for jog commands, boolean
    [13:02:03] [ $$ ] $43=1 ;Homing passes
    [13:02:03] [ $$ ] $44=4 ;Homing cycle 1
    [13:02:03] [ $$ ] $45=3 ;Homing cycle 2
    [13:02:03] [ $$ ] $46=0 ;Homing cycle 3
    [13:02:03] [ $$ ] $62=0 ;Sleep Enable
    [13:02:03] [ $$ ] $63=2 ;Feed Hold Actions
    [13:02:03] [ $$ ] $64=0 ;Force Init Alarm
    [13:02:03] [ $$ ] $65=0 ;Require homing sequence to be executed at startup
    [13:02:03] [ $$ ] $70=7 ;Network Services
    [13:02:03] [ $$ ] $73=1 ;Wifi Mode
    [13:02:03] [ $$ ] $74=NaN ;Wifi network SSID
    [13:02:03] [ $$ ] $75=NaN ;Wifi network PSK
    [13:02:03] [ $$ ] $100=26.667 ;X-axis steps per millimeter
    [13:02:03] [ $$ ] $101=26.667 ;Y-axis steps per millimeter
    [13:02:03] [ $$ ] $102=200.000 ;Z-axis steps per millimeter
    [13:02:03] [ $$ ] $110=8000.000 ;X-axis maximum rate, mm/min
    [13:02:03] [ $$ ] $111=8000.000 ;Y-axis maximum rate, mm/min
    [13:02:03] [ $$ ] $112=250.000 ;Z-axis maximum rate, mm/min
    [13:02:03] [ $$ ] $120=150.000 ;X-axis acceleration, mm/sec^2
    [13:02:03] [ $$ ] $121=150.000 ;Y-axis acceleration, mm/sec^2
    [13:02:03] [ $$ ] $122=150.000 ;Z-axis acceleration, mm/sec^2
    [13:02:03] [ $$ ] $130=1550.000 ;X-axis maximum travel, millimeters
    [13:02:03] [ $$ ] $131=3050.000 ;Y-axis maximum travel, millimeters
    [13:02:03] [ $$ ] $132=80.000 ;Z-axis maximum travel, millimeters
    [13:02:03] [ $$ ] $300=NaN ;Hostname
    [13:02:03] [ $$ ] $302=192.168.5.1 ;IP Address
    [13:02:03] [ $$ ] $303=192.168.5.1 ;Gateway
    [13:02:03] [ $$ ] $304=255.255.255.0 ;Netmask
    [13:02:03] [ $$ ] $305=23 ;Telnet Port
    [13:02:03] [ $$ ] $306=80 ;HTTP Port
    [13:02:03] [ $$ ] $307=81 ;Websocket Port
    [13:02:03] [ $$ ] $341=0 ;Tool Change Mode
    [13:02:03] [ $$ ] $342=30.0 ;Tool Change probing distance
    [13:02:03] [ $$ ] $343=25.0 ;Tool Change Locate Feed rate
    [13:02:03] [ $$ ] $344=200.0 ;Tool Change Search Seek rate
    [13:02:03] [ $$ ] $345=100.0 ;Tool Change Probe Pull Off rate
    [13:02:03] [ $$ ] $370=0 ;Invert I/O Port Inputs (mask)
    [13:02:03] [ $$ ] $384=0 ;Disable G92 Persistence
    [13:02:03] [ $$ ] ok
    [13:02:03] [ $I ] [VER:1.1f.20220325:workbee1510]
    [13:02:03] [ $I ] [OPT:VNSL2,35,1024,3,0]
    [13:02:03] [ $I ] [NEWOPT:ENUMS,RT+,HOME,TC,SED,WIFI,SD]
    [13:02:03] [ $I ] [FIRMWARE:grblHAL]
    [13:02:03] [ $I ] [NVS STORAGE:*FLASH]
    [13:02:03] [ $I ] [DRIVER:ESP32]
    [13:02:03] [ $I ] [DRIVER VERSION:220327]
    [13:02:03] [ $I ] [DRIVER OPTIONS:v4.3.2-555-gb4ef1b80a2-dirty]
    [13:02:03] [ $I ] [BOARD:BlackBox X32]
    [13:02:03] [ $I ] [AUX IO:1,0,0,0]
    [13:02:03] [ $I ] [WIFI MAC:94:B5:55:31:02:C0]
    [13:02:03] [ $I ] [IP:0.0.0.0]
    [13:02:03] [ $I ] [PLUGIN:SDCARD v1.05]
    [13:02:03] [ $I ] [PLUGIN:ESP32 WebUI v0.03]
    [13:02:03] [ $I ] ok
    [13:02:03] [ $G ] [GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
    [13:02:03] [ $G ] ok
    [13:02:04] [ connect ] Firmware Detected: grbl version 1.1f on COM5
    Make sure to click the X32 tab. Even if it's already selected. That seems to be trying to flash a 4X. Might have a bug with the default selection, so lets test if clicking the tab to assert the controller type helps.
    FredStein likes this.
  3. FredStein
    FredStein New
    Thanks Peter.
    Partial success.
    • I positively selected each option:
    • X32
    • FTDI USB to Serial COM5
    • 2/3 Axes CNC/Laser: Dual Y
    The Update Log is:
    [15:19:18] [ Firmware Upgrade ] [Starting...]
    [15:19:20] [ disconnect ] PORT INFO: Port closed
    [15:19:20] [ Firmware Upgrade ] esptool.py v2.6 Serial port COM5 Connecting...
    [15:19:20] [ Firmware Upgrade ] .
    [15:19:21] [ Firmware Upgrade ] .
    [15:19:22] [ Firmware Upgrade ] Chip is ESP32D0WDQ6 (revision 1) Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None MAC: 94:b5:55:31:02:c0 Uploading stub... Running stub... Stub running... Changing baud rate to 460800 Changed. Configuring flash size... Auto-detected Flash size: 4MB Compressed 17104 bytes to 11850... Writing at 0x00001000... (100 %)
    [15:19:22] [ Firmware Upgrade ] Wrote 17104 bytes (11850 compressed) at 0x00001000 in 0.3 seconds (effective 476.8 kbit/s)... Hash of data verified. Compressed 3072 bytes to 131... Writing at 0x00008000... (100 %)
    [15:19:22] [ Firmware Upgrade ] Wrote 3072 bytes (131 compressed) at 0x00008000 in 0.0 seconds (effective 1536.0 kbit/s)... Hash of data verified. Compressed 877856 bytes to 593513... Writing at 0x00010000... (2 %)
    [15:19:23] [ Firmware Upgrade ] Writing at 0x00014000... (5 %)
    [15:19:23] [ Firmware Upgrade ] Writing at 0x00018000... (8 %)
    [15:19:24] [ Firmware Upgrade ] Writing at 0x0001c000... (10 %)
    [15:19:24] [ Firmware Upgrade ] Writing at 0x00020000... (13 %)
    [15:19:24] [ Firmware Upgrade ] Writing at 0x00024000... (16 %)
    [15:19:25] [ Firmware Upgrade ] Writing at 0x00028000... (18 %)
    [15:19:25] [ Firmware Upgrade ] A fatal error occurred: Failed to write compressed data to flash after seq 6 (result was C100)
    [15:19:25] [ Firmware Upgrade ] [exit:2]
    [15:19:25] [ Firmware Upgrade ] Firmware Update FAILED! Please review the logs above, or try again
    Just try again, it seems comms was interrupted
  5. FredStein
    FredStein New
    Morning Peter.
    This seems to be an issue that just keeps giving.
    This morning, when I went to try the firmware update again, I cannot connect to the X32.
    I have read 6.3 and wiring is unchanged, COM port is good, drivers are good (2.12.36.4 07/05/21).
    The only change made is to remove a USB extension cable in order to minimise the potential for another comms interruption.
    Log screen dump follows.
    Thanks,
    Fred.
    [11:31:35] [ ] entry 0x400805e4
    [11:31:35] [ ] ets Jun 8 2016 00:22:57
    [11:31:35] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [11:31:35] [ ] configsip: 0, SPIWP:0xee
    [11:31:35] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [11:31:35] [ ] mode:DIO, clock div:2
    [11:31:35] [ ] load:0x3fff0030,len:1184
    [11:31:35] [ ] load:0x40078000,len:12784
    [11:31:35] [ ] load:0x40080400,len:3040
    [11:31:35] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [11:31:36] [ ] configsip: 0, SPIWP:0xee
    [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [11:31:36] [ ] mode:DIO, clock div:2
    [11:31:36] [ ] load:0x3fff0030,len:1184
    [11:31:36] [ ] load:0x40078000,len:12784
    [11:31:36] [ ] load:0x40080400,len:3040
    [11:31:36] [ ] entry 0x400805e4
    [11:31:36] [ ] ets Jun 8 2016 00:22:57
    [11:31:37] [ ] ets Jun 8 2016 00:22:57
    [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [11:31:37] [ ] configsip: 0, SPIWP:0xee
    [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [11:31:37] [ ] mode:DIO, clock div:2
    [11:31:37] [ ] load:0x3fff0030,len:1184
    [11:31:37] [ ] load:0x40078000,len:12784
    [11:31:37] [ ] load:0x40080400,len:3040
    [11:31:37] [ ] entry 0x400805e4
    [11:31:38] [ ] ets Jun 8 2016 00:22:57
    [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    [11:31:38] [ ] configsip: 0, SPIWP:0xee
    [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    [11:31:38] [ ] mode:DIO, clock div:2
    [11:31:38] [ ] load:0x3fff0030,len:1184
    [11:31:38] [ ] load:0x40078000,len:12784
    [11:31:38] [ ] load:0x40080400,len:3040
    [11:31:38] [ ] entry 0x400805e4
    [11:31:38] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port COM5
    [11:31:39] [ disconnect ] PORT INFO: Port closed
    That's the half-written firmware from the day before, unable to boot of course (it didn't finish writing remember).
    Usb Extensions are a bad idea, and should be the cause of the comms drop during flashing the day before.
    Complete a successful firmware flash first.
