We are all struggling with the 3D Systems Cube 3 cartridges.
One problem solved, we can remove the write operation to the cartridges.
...creating a new problem as the cartridges are prone to failure.
This build attempts to correct this by extending the longevity of the parts provided with OEM cartridges.
In addition, this upgrade also allows for hot-swapping filament mid-print.
This is part of a larger project that will likely spawn from this in discussion, but suffice it to say at this point that the extruder is only part of the system. You will be expected to provide a 4mm OD filament feeder tube to the module using push-to-connect tubing and fittings. There are several offerings to accomplish this. It is my hope that these additional elements will come out in the discussion. I will say that this has been accomplished with great success. And I will also give credit to those who have endeavored to get to this point. These contributors too will be highlighted as the discussion progresses.
I will start by providing 4 images where those with the ability can move ahead.
The finer bits. The tube is stock 3DS 2.8mm Teflon tube salvage.
Threaded and counter-bored (~10mm)
Aim for the middle of this bar. Drill 2.8mm at 15 degrees.
3DS Cube 3 Modular Extruder
Build in '3D PRINTER BUILDS' published by Tom Dirriwachter, Mar 19, 2017.
How to modularize the 3D Systems Cube 3 extruder nozzle.
Some level of expertise in modifying existing parts is required.
Build Author Tom Dirriwachter, Find all builds by Tom Dirriwachter
Extending the life of 3DS cartridgesInspired by
This is a group project from a Cube 3 subforum Cube3 -
Qty Part Name Part Link Comments 1 Push-to-connect fitting, M5 thread, 4mm OD tube https://www.amazon.com/uxcell-Thread-Pneumatic-Connector-... Link Minimal barrel diameter is a plus
