      The XYZ linear system is equipped with 4 stepper motors. With the robust v-Slot profiles from OpenBuilds, the machine is ideally equipped for daily use as well as for the hobby cellar.
      Ideal for
      • Laboratory automation
      • Laser Cutter
      • Pick and Place
      • Measuring machines
      • and many other CNC applications
      The profile length of the Z-axis is 250 mm as standard.
      The travel in the Y-direction is reduced by about 150 mm. The travel in the X-direction is also reduced by 150 mm + any attachments.
      montegofd3s and Mark Carew like this.
    We were looking for a robust build driven system with good precsision and and a good range of work area to footprint.
    Acro System
    4 NEMA 17 Stepper Motor Link
    3 V-Slot® 20x40 Linear Rail https://openbuildspartstore.com/v-slot-20x40-linear-rail/ Link 1000mm
    2 V-Slot® 20x20 Linear Rail https://openbuildspartstore.com/v-slot-20x20-linear-rail/ Link 1000mm
