I have no past knowledge of CNC router nor machinery of any sort. However I am a computer case modder/designer as a hobby. While I was having difficulties on having the parts I need from shops, I suddenly came up with the idea of building a machine of my own. After reading, watching openbuilds community builds I have (i think) learned a lot and wanted to give it a go finally.
I had to source the parts I need from 3 different places. First is the openbuilds US (almost all bits except the ones bigger in size due to logistics difficulties), second is ooznest (openbuilds UK) for c-beam slots and lead screws and the last one is a local manufacturer, who produces sigma profiles here in Istanbul.
This is currently where I am, I have all c-beam slots and sigma profiles I need for the main frame, while I still have to wait till end of March to have other parts in my hands to start building C-BEAM-GTC. GTC stands for my nickname (GinoTheCop) and I try to stick with that with my designs/builds.
C-BEAM-GTC will be a larger version of C-BEAM and it will have a cutting area of 720 by 820 mms. Will be powered by 4 nema 23 size motors and controlled by CNC- XPro V2. A DeWalt 26200 router will be used.
This project will help my nephew, who is currently studying electric-electronic engineering so I will build this project together with him.
The build is upgraded for a more sturdy Z gantry and spindle mount. Used Sphinx method (double anti backlash nuts on all gantries).
You can see an overview, specs and all by downloading this PDF file
I am using fusion 360 for the design and below is a render taken from the latest state.
The update design can be followed from here
And a simulation video from Fusion:
You may have a look at the designs and also download in IGES - SAT- SMT - STEP - DWG - DXF- STL - FBX - SketchUp - OBJ formats from below links. (You will reach to the latest versions as I keep working on them and I will confirm the parts are 100% compatible once I finish the upgrade)
X PLATE FRONT
X PLATE BACK
X GANTRY ASSEMBLY
Z PLATE
Z GANTRY ASSEMBLY
Y PLATE
Y GANTRY ASSEMBLY RIGHT
Y GANTRY ASSEMBLY LEFT
Wish me luck, and thanks for reading...
C-BEAM-GTC
Build in 'Cartesian Style CNC' published by GinoTheCop, Mar 12, 2017.
Building a larger C-BEAM CNC Machine with no previous experience.
Lloydsch47, livio, Cyellow and 63 others like this. -
Build Author GinoTheCop, Find all builds by GinoTheCop
I want to be able to learn more about machines while I want my nephew to have some experience in mechanics, electronics and electric.Inspired by
C-Beam Sphinx Build / C-Beam / MakerSL MSL-8 OB Vise -
![[IMG]](proxy.php?image=https%3A%2F%2Ffarm6.staticflickr.com%2F5641%2F30289654184_3b16bed0dc_b.jpg&hash=93832f0015cde2e4d52e4dec1d41c31c)
