[ 3/15/17 ]
This is the build log for my first CNC machine based on the C-Beam Plate Maker. Plan is for the addition of limit switches, custom UI, and probably lots of learning.
I had been planning on building a CNC mill for a few years since I got my first 3D printer up and running and was ready to move from prototyping parts in plastic before cutting in metal. Finally pulled the trigger as I was tired of hearing my son complain about how I was complaining about not having the time! Project started in earnest with the arrival of 3 packages on the same day.
As I'm sure anyone who has used the Open Builds Parts Store already knows, they sure know how to pack a box! The other two were the controller board and stepper motors.
Having lost all semblance of patience I immediately dove in.
[ 3/24/17 ]
Finally got to the local lumber store to pick up some 1/2" MDF for the base/spoiler board. Hoping to get some time this weekend to finish the assembly of the last axis and the frame.
[ 3/25/17 ]
Got the MDF cut. For the mount plate (the bottom one) I am using 20mm M4 screws with M4 tee-nuts that are recessed so the spoiler board will lay flat on top.
[ 3/26/17 ]
Assembly mostly done. Waiting on wire, limit switches, a few other bits and pieces to start connecting the electronics.
[04-06-17]
Finally had a bit of time to temp wire up the electronics and see what happens.
[ 04-19-17]
Power distribution box for the mill side. There will be one at the control box side as well. Using STP wiring for interference reduction.
C-Beam Intro to CNC
Build in 'X/Y Table Style CNC Mill' published by Greg Lampman, Aug 22, 2017.
Build log for my first CNC machine, a C-Beam Plate Maker
The boxes used for the power/signal distribution came from Thingiverse ("The Ultimate Box Maker" @ www.thingiverse.com/thing:1264391
Mark Carew, Tam Findlay and alex_b like this. -
Build Author Greg Lampman, Find all builds by Greg Lampman
It was the logical progression after the 3D printer. Of course it now has spawned visions of a CNC Lathe, a 4 or 5-axis mill, a laser cutter....where does it all end?Inspired by
The original by Mark Carew - C-Beam™ Machine - Plate Maker -
Qty Part Name Part Link Comments 1 C-Beam Machine Mechanical Bundle http://openbuildspartstore.com/c-beam-machine-mechanical-... Link All the hardware to get you started 1 16mm Thread 4 Pins Male Female Panel Connectors https://www.amazon.com/gp/product/B016FCZ5SS/ref=oh_aui_d... Link For Stepper power cables and limit switch cables between CNC and controller 1 Red Lamp Self Locking Emergency Stop Switch https://www.amazon.com/gp/product/B008LT2VH2/ref=oh_aui_d... Link Emergency stop switch 1 2.54mm JST-XHP JST Connector Kit https://www.amazon.com/gp/product/B01MCZE2HM/ref=oh_aui_d... Link For JST connectors on controller card to stepper outputs 1 XH2.0mm XH2.54mm XH3.96mm Dupont D-Sub Crimper https://www.amazon.com/gp/product/B00YGLKBSK/ref=oh_aui_d... Link Crimping tool for the JST contacts 1 Limit Switches https://www.amazon.com/gp/product/B00MFRMFS6/ref=oh_aui_d... Link For X, Y and Z limit switches 1 30mm x 15mm Drag Chain https://www.amazon.com/gp/product/B01M099ZQX/ref=oh_aui_d... Link For X-axis and Z axis wiring runs 1 Braided Wire Sleeving https://www.amazon.com/gp/product/B00V3PQR08/ref=oh_aui_d... Link To clean up the look of the wiring runs 1 24V 15A 360W DC Universal Regulated Switching Powe https://www.amazon.com/gp/product/B01IOK5FM0/ref=oh_aui_d... Link Power supply for stepper motors 1 Nema 23 CNC Stepper Motor 2.8A 179oz.in 56mm Bipol https://www.amazon.com/gp/product/B00QG1ZF48/ref=oh_aui_d... Link Came in package of 3 for axis drive motors 1 Smoothieware MKS SBASE V1.3 32-Bit Controller https://www.amazon.com/gp/product/B01FVT5VA8/ref=oh_aui_d... Link Controller card
